Help!!!!!! Amp problems
Old Jul 7, 2003 | 07:23 PM
paper1122's Avatar
A-CL Fanatic
I just bought an amp for my subwoofer (10" xplode) And it started overheated(i think). It's been shutting off and it is very hot to the touch. I think it is the ground wire, could this be possible? Anyone with idea's? Thanks a bunch.
Old Jul 7, 2003 | 09:14 PM
mcdanjw's Avatar
It could be something with the wiring to the speaker.
How did you hook up the speaker? Stereo, mono bridged, or what? Is it 1 sub or 2?
Old Jul 7, 2003 | 09:46 PM
paper1122's Avatar
A-CL Fanatic
It is one 10" hooked up mono bridged across the two channel amp
Old Jul 8, 2003 | 09:23 AM
KyleWatson's Avatar
The amp is most likely running at 4 ohm mono... Give us some more details, amp brand and model, size of power and ground wire, where the gain is set, and if the sub in a 2 or 4 ohm speaker, dual or single voice coil?
Old Jul 8, 2003 | 11:56 AM
mcdanjw's Avatar
What he said...
Old Jul 8, 2003 | 12:45 PM
paper1122's Avatar
A-CL Fanatic
The amp is a bazooka 2100, 500watt max.
115 watts RMS x 2 at 4 ohms
165 watts RMS x 2 at 2 ohms
330 watts x 1 in bridged mode
stereo or bridged mono output
Tri-Way capable
variable high-pass/low-pass crossover, 12 dB per octave
MOSFET output devices
bass boost
output port for easy connection of Bazooka EL-series amplified bass tube
speaker-level and preamp-level inputs let you connect to any radio, factory or aftermarket
Dimensions: 11-13/16"W x 2-5/8"H x 10-1/4"D
The sub is a sony xplode 10"
High-rigidity compound Polypropylene cone
4-layer 4-ohm voice coil
Durable Santoprene rubber surround
Stroke stabilizer
Double damper suspension
Gold-plated binding posts
SUB SPECS:
Rec. Sealed Box Dims: 0.70 cu.ft.
Rec. Ported Box Dims: not recommended
Free Air Usage: not recommended
Sensitivity: 89 dB
Frequency Response: 25-2,800 Hz
Recommended RMS Power: 250W
Peak Power Handling: 700W
Impedance: 4 ohms
I have the gain set at around 6db
Old Jul 8, 2003 | 01:38 PM
spdy0001's Avatar
I now drive an accord....
Its a wiring problem
or a short in the voice coil of your sub. Try disconnecting the sub from the output of the amp and watch the power light to see if it shuts off. If it doesn't then you know its not the amp.
Old Jul 8, 2003 | 02:00 PM
mcdanjw's Avatar
Weird. Looks like everything should work right, assuming all the wires are in the right place. Like spyd said, I'd double check that.
Checking the ground is a good idea, though I haven't personally seen a bad ground make an amp run hot... it usually just won't run.
I have had several amps do what you described and it turned out the amp was jacked up...
Is this a new amp or something from eBay or what?
For shits and giggles, you could try hooking your sub up to one channel of the amp in stereo mode just to see if the amp will run for an extended period in that mode without overheating.
Old Jul 8, 2003 | 02:06 PM
paper1122's Avatar
A-CL Fanatic
I bought the amp from Circuit City open box.... I am thinking that you may be right that the amp is jacked up. I am going to also try running it in stereo mode like you suggested, and I relocated the ground. So we'll see what happens, thanks for your advice.
Old Aug 14, 2003 | 06:41 PM
RR32CLS's Avatar
"hey...wanna f^&k"
first, its a bazooka amp.
second, its called sony XPLODE for a reason.
return that garbage back and get semething else, anything but sony and bazooka.
Old Aug 14, 2003 | 06:49 PM
wuzzz619's Avatar
Old Aug 14, 2003 | 08:39 PM
KyleWatson's Avatar
What size power wire? Is the ground the same size? It could be a screwed up amp.... Did you scrape the metal free of paint before attaching the ground? What size fuse is in the power wire at the battery?
Old Aug 15, 2003 | 11:29 AM
paper1122's Avatar
A-CL Fanatic
I got the situation fixed I think, I returned the bazooka amp, and picked up an alpine amp off someone from the board. The sony sub works great, especially at the price I got it at.
Old Aug 18, 2003 | 12:46 PM
sonor kid's Avatar
One who Laps
I agree with the Bazooka comment but Sony makes some nice equipment in their ES line.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
