Flex in door windows?
Old Jun 9, 2003 | 06:52 PM
bozzchem's Avatar
I've braced my door cutout with a 3/4in. spacer on the front and rear of the cutout. Talk about stiff...
Anyway, I noticed with the speaker mounted in a 1/4in spacer to go on top of the 3/4in spacer (1 1/4in total), there was like a 1/4 in or so gap between the magnet and the window rolled down.
I could easily make another 3/4 in spacer to make for a total of a 1 1/2in spacer.
My question is concerning the risk of the window smacking into the back of the speaker and breaking. Is there a risk? Should I just go ahead and use two 3/4 spacers?
What can I expect in terms of getting the door panel back on?
Thx.
Old Jun 10, 2003 | 04:56 PM
dnd2984's Avatar
That was a big concern I had to. I did have my windows down during the install and had about half a inch to a inch of gap bewteen the window left.
Old Jun 10, 2003 | 10:40 PM
I have the same clearence on my front doors. Have not had a problem. The glass and rails are pretty rigid. I don't belive they flex any more than 1/16-1/8 if any. It may be easier for you two add some washers to the bolts that hold the rails to the inside of your door panel this will push the rails / window a little further away from the magent. Else you may have to deal with your speaker being too tight against the door panel. But if you clearly have 1/4 icnh then you will probably be fine. I also put 3m strip calk behind the mdf spacer which game me almost another 1/4 inch of clearence.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
soupi
14
Nov 15, 2015 11:15 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
