Finally took some pics of my system!!
Old Jun 10, 2004 | 01:47 PM
04Carbon6's Avatar
Git er Done!!
My little Sirius install in the upper pocket
Eclipse EQ in the glove box
Aux audio inputs down on the floor so I can hook up an MP3 player or something
Custom trunk install. There is a 1.5 farad digital cap on a stand behind the left amp.
My Kenwood Music Keg installed in the trim board.
Sirius antenna slightly modified to fit under the brake light.
I had the same rattles that everyone else had in their doors. So when I had all the door panels off I went crazy with the dynamat. Also something else that annoied me with the car are the how the door locks don't sit flush when the are locked. So I modified those when I had the panels off.
Old Jun 10, 2004 | 01:54 PM
biker's Avatar
Old Jun 10, 2004 | 02:07 PM
BlackTSX's Avatar
Jewdacris!!
The locks look nice, im guessing with the dynomat the rattles are less? Also how do you like that music keg?
Old Jun 10, 2004 | 02:17 PM
04Carbon6's Avatar
Git er Done!!
Yep, ALL rattles are gone!
I love my music keg. This is my second one. I had one in my Integra, but that one got wrecked with the car. I have all the music that's on my computer in my car and it all gets controled through the Sirius controler so I can know what folder or song I'm on.
Old Jun 10, 2004 | 02:22 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
I'm wondering how you modified your door lock because they too have bugged me. I was thinking of totally removing them but that would leave a hole in the panel. Looks great flush like that, how'd you do it?
Old Jun 10, 2004 | 02:38 PM
Dan Martin's Avatar
Photography Nerd
Do they just unscrew?
Old Jun 10, 2004 | 04:50 PM
acuratsx03's Avatar
Future Seminole
thats awesome. a very nice setup. no front speaker upgrades though? i find that if i want to turn my bass up higher, i cant cause the front doors get all distorted and muddy, so out those go and in go type r components...
Old Jun 10, 2004 | 06:17 PM
e_lectro's Avatar
Still here
If you were going to go through the trouble of dynamating your doors like that, you should have used some metal sheets to fill in those large holes... would have made your door like a sealed enclouse and resulted in better sound, exp with aftermarket speakers.
Old Jun 10, 2004 | 07:56 PM
04Carbon6's Avatar
Git er Done!!
For the door locks all you have to do is unscrew the door lock thingy and cut off some off the bottom (start cutting small and just work your way up, because there's no turning back). Then I had to bore out the hole a little and then just screw it back on. It won't get a tight as it used to be but that's no big deal.
Actually I upgraded ALL the speakers. I have Rockford Fosgate Fanantic Components up front, Fosgate 6.5" 2way titanium speakers in the rear doors, and Fosgate 3way 6x9's in the rear deck. The ones in the front doors just have a plain look to them. They don't have the bling factor that other aftermarket speaker do.
That thought actually crossed my mind, but I just didn't have the time or the resources to do that.
Old Jun 11, 2004 | 06:42 PM
Deelover's Avatar
satellite, 5 cd changer, and the music keg... you have enough music to listen to songs for years. I have XM and havent listened to a CD or FM since.
Old Jun 12, 2004 | 01:43 AM
04Carbon6's Avatar
Git er Done!!
Hell yeah dude....my friends have officially made my car the road trip car
Old Jun 12, 2004 | 02:11 AM
CGTSX2004's Avatar
Hmm...the door lock thing is pretty cool. I think I may try that sometime. Think maybe using some thread-locker might get it in tighter?
Old Jun 12, 2004 | 03:30 PM
gmfreed's Avatar
I like the locks, my VW used to be like that. But on German cars, you jusy pull the inside handle and it releases the lock. Has anybody thought about what would happen if you had an electrical failure and you can't pull your locks up to get out of your car? Or even just a car accident that messed up the battery so you have no power. But atleast it looks good, I am just anal enough to do that, just so the door looks that much better.
Old Jun 12, 2004 | 03:38 PM
Revenent's Avatar
Evil Empire Peon
Actually, that's probably why Acura/Honda didn't make it flush. It's a safety issue more than anything.
One blown fuse could get you locked in your car.
Old Jun 12, 2004 | 03:42 PM
e_lectro's Avatar
Still here
You could always make that part of your alarm system
Old Jun 12, 2004 | 03:43 PM
Revenent's Avatar
Evil Empire Peon
He he he - somehow, when you're inside the car, it's not that big of an issue.
Old Jun 12, 2004 | 03:46 PM
elduderino's Avatar
VP Electricity
Actually, now you've got me thinking... an alarm backup battery, a single relay, and my driver's door switch could unlock the door even with a dead battery!
Now the question is: Do I try to get another set of wires into the door, or do I try to mount the alarm backup battery securely inside the door?
Old Jun 12, 2004 | 03:49 PM
Revenent's Avatar
Evil Empire Peon
It depends on how much power the batteries need to have to power the lock.
It might be easier to run the wires in to the panel since then you can change the batteries if necessary.
Old Jun 12, 2004 | 04:01 PM
elduderino's Avatar
VP Electricity
That boot doesn't seem to have much room, and I might use it all with the lock/arm/disarm wires I'm going to run in there already.
Of course, I need to remember that there is no right way to do something stupid, and my idea might be covered by that pearl of wisdom.
Old Jun 13, 2004 | 01:21 AM
04Carbon6's Avatar
Git er Done!!
CGTSX2004 - Thread locker is a good thing to try but I'm not sure how well it works with plastic
As for the lock not able to be manually pulled up, I did think about that issue of not being able to get out of my car. But I did not modify the rear locks, so if I had to I could get out through the rear doors if necessary. I just had to make the locks flush in the front, because I always put my arm up there and I always used to hit my elbo on that freakin thing. I never had that problem with my Integra because the lock was with the door handle, which is how the TSX should be. Anyway I'm not that worried about electrical failure in an accident, because after my crash in my Integra everything still worked. If you haven't seen the pics of it, the driver's door was crushed into the driver's seat and the power door lock still worked.
jspangan
ILX
19
Aug 30, 2016 05:37 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
usual suspect
2G TSX Photograph Gallery
Dec 7, 2015 10:52 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
