TSX: Factory amp bypass idea
Old Jun 13, 2011 | 08:38 AM
Duriisimo's Avatar
Aguilucho del Cibao!
IDEA to bypass the factory amp on the 04 TSX:
Use the male and female harness,leaving the speaker outputs from the radio exposedand and into a LOC and not CUT any factory harnesses? Will I lose the steeringwheel controls?
Thoughts, thanks
Old Jun 13, 2011 | 11:16 AM
CCColtsicehockey's Avatar
This works as I did make one however you can also just use this piece from an RSX and it works fine. I have no engine whine with my amp that I can tell.
It basically does exactly what you are talking about but gives you RCA output instead of speaker wire.
Old Jun 13, 2011 | 12:47 PM
Duriisimo's Avatar
BEtter Idea but will I keep the steering wheel controls?
Old Jun 13, 2011 | 01:02 PM
Yes you will still keep the steering wheel controls.
Old Jun 13, 2011 | 01:56 PM
Duriisimo's Avatar
Thank you for your advice
Old Jun 25, 2011 | 01:35 PM
pyarali's Avatar
4th Gear
Can I install after market Navigation on 2007 acura tsx
Old Jun 29, 2011 | 07:15 AM
Duriisimo's Avatar
No steering wheel controls after installing the PAC OEM1. Any advice?
Old Jun 29, 2011 | 03:22 PM
Duriisimo's Avatar
Nevermind, yesterday I was not man enough to properly and securely connect the 2 harnesses but i got a good nights sleep and a good breakfast and figured out the problem and connect them securely.
Old Jul 23, 2011 | 11:44 AM
gamekiller04's Avatar
Which piece from an RSX
4drviper
Apr 23, 2025 07:13 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
kixo
Sep 25, 2015 03:07 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
