eq bypass
Old Feb 12, 2004 | 02:31 PM
fsttyms1's Avatar
eq bypass
im installing a new headunit right now and was wondering if i should bypass the EQ? the new headunit has a very nice built in eq with just about every imaginable eq setting. im still running factory speakers, right now any way but will upgrade soon
any imput would be helpfull
thanks
kris
Old Feb 12, 2004 | 02:53 PM
AcuraX2's Avatar
If you are replacing the head unit and using a wiring harness adapter, the factory EQ does not come into play. You are taking it out of the signal chain.
Old Feb 12, 2004 | 03:14 PM
njtls's Avatar
let me know how your headunit sounds with your factory speakers...cause mine sound like crap
Old Feb 12, 2004 | 03:30 PM
fsttyms1's Avatar
cool thanx!
and njtls, ill let ya know when i get it installed, im waiting for the paint to dry on the dash kit
Old Feb 12, 2004 | 10:21 PM
Scott P's Avatar
Mobile Elec. Guru
i can speak to how the factory speakers sound with just a headunit. there is a noticible difference one the factory eq is out of the loop, and the spk's are given free reign to play full range. That being said they are still stock speakers running off the stock amp, so there are obviously limitations in their performance. None the less i would rate them as equivelant to a low end aftermarket speaker in sound reproduction, and not too bad as a temp solution if you are merely trying to bide time while building a system piece by piece.
Old Feb 15, 2004 | 07:15 PM
Ianbiz3's Avatar
how do u pass the factory eq?? if i did that, and put aftermarket speakers it should sound good. right?
Old Feb 15, 2004 | 08:50 PM
fsttyms1's Avatar
scroll down about half way for the directions on bypassing the EQ
http://www.acura-tl.com/forum/showth...threadid=20860
and yes better speakers will help improve the sound!
tsx_boy
Dec 13, 2019 08:33 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
frozenpenguins
Aug 29, 2015 12:54 AM
