car capacitor draining car battery? 2004 tsx
honk not beep
I have a 1 farad cap and two amps being run from it. When I go travel on work and leave my idle for like 5 days, my battery dies where I need a jump.
Is it the case that with a stock battery, my cap is draining the car battery if I leave it by itself?
Unless the cap is defective the leakage current is miniscule and will not drain your battery. You could have a defective battery or too high of a parasitic drain on the system. You should have the battery load tested as well as the current drain from the battery the ignition off.
The next time you go away on a trip pull the inline fuse to your amp and see if the battery still drains. If it doesn’t then check to see if your amp is shutting off. If it goes dead with the fuse out then have the car and battery checked.
jeff
jeff
honk not beep
i think i have my culprit while doing some checking. After taking the key out of my ignition, my amps do turn off, but i have a dension ipod icelink which still charges the ipod even after everything is off.. hmm...
