Blown Tweeter?
Old Apr 29, 2009 | 01:38 PM
Futureman's Avatar
Blown Tweeter?
I have stock everything. Except for all of my speakers are aftermarket. I think I blew my tweeter, it was making a buzzing sound, and now there is no sound coming from it. Should I take it to an audio place, and have it checked out, or is it cooked?
Old Apr 30, 2009 | 02:07 AM
on1wheel01's Avatar
well if it doesnt work then it's prolly blown
Old Apr 30, 2009 | 08:36 AM
Jonesi's Avatar
If you can't do it I'd have it looked at for sure..
Old Apr 30, 2009 | 11:26 AM
Futureman's Avatar
Thanks. Yah, I don't want to just throw it away. I thought the stock amp had an internal crossover for the tweeter, and I am running all my speakers off the stock amp currently with out installing my aftermarket crossovers. Maybe it was receiving frequencies it couldn't handle.
Old Apr 30, 2009 | 02:22 PM
nbpc's Avatar
3rd Gear
You can check it out
I had blown tweeters and I found a couple sites that told you how to know for sure.
If you have a multimeter, with the radio off, check the resistance (OHMS) across the two terminals. If it's zero, you're good. If not, bad.
Old Apr 30, 2009 | 02:31 PM
mattastick's Avatar
the resistance across a speaker should never be zero... it's always showing a resistance, same as any other resistor...
Old Apr 30, 2009 | 03:31 PM
on1wheel01's Avatar
lmao yea it should show what ohm the speakers are lol
Old Apr 30, 2009 | 04:27 PM
nbpc's Avatar
3rd Gear
Yup, my bad.
Still, hope it helps.
Old Apr 30, 2009 | 04:29 PM
dave586270's Avatar
Chamorro
I was having the same problem and it turned out the connection was just loose. I don't know if it will be as simple for you, but pop off the tweeter from the door and check to make sure that its plugged in all the way. My cables were literally just barely staying connected. I just popped them back together and BAM! She was all good. Hope its as simple for you man.
Old Apr 30, 2009 | 04:57 PM
Futureman's Avatar
I think its plugged in all the way, as the tweeter from the other side works on the drivers side. the soldered connection to the tweeter seems pretty solid, maybe the polarity is switched tho?
Old Apr 30, 2009 | 08:00 PM
dave586270's Avatar
Chamorro
I dunno. Sorry it wasn't so simple as my problem. Good luck.
Old May 1, 2009 | 04:24 PM
Futureman's Avatar
Dave, have you ever done a Crank pulley on the CL before?
Old May 4, 2009 | 03:53 PM
dave586270's Avatar
Chamorro
No, sorry man. I was looking into it a while ago cause i guess its a decently cheap mod. But once i found out the labor to do it, i figured i'd just put the money into something else. Lookin to get a lighter one?
4drviper
Apr 23, 2025 07:13 PM
ripit
Sep 26, 2015 06:19 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
polish_pat
Sep 25, 2015 12:24 PM
STC
Sep 23, 2015 04:36 PM
