Big 3??
Old 10-08-2008 | 05:07 AM
eleventure's Avatar
Big 3??
I've been wanting to do the big 3 ever since I realized that my 2.0 farad cap isnt enough for my 1000 watt amp at loud volumes (lights dim).
Just out of curiosity, How many of you guys have done the big 3 for your audio system? Has it made a noticeable difference? Please provide pics if you have. Just want to get an idea on how I should run the wire from the alt to the batt. Thanks
Old 10-08-2008 | 11:30 AM
wong05tsx's Avatar
Need more room in
i have.. running 1600ish rms to the subs, 500ish rms to the speakers.. with just a bettery upgrade and big 3, no dimming
cap is a waste of money imo..
as for running the wire, just run it however you can that will make it look stealthy (thats if u're anal about seeing the wire), and away from anything that may become hot
Old 10-08-2008 | 11:58 AM
uncald4's Avatar
Former Sponsor
WOW!!
I could not have said it better myself.
Old 10-08-2008 | 03:32 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
What kind of battery are you running?
Old 10-08-2008 | 05:33 PM
Costco's Avatar
Whats the big 3? I'm guessing battery, alternator, ???
My boss also told me something people forget is to upgrade the ground wire going from the negative battery post to the chassis. Is that going to help at all? I thought it would since usually that wire is usually pretty small and looks corroded like hell.
Old 10-09-2008 | 01:09 AM
wong05tsx's Avatar
Need more room in
Battery negative to chassis
Alternator Positive to Battery Positive
Alternator ground to chassis
Big 3
and I'm running a Optima Yellow top D51 (Biggest yellow top that can fit a tsx)
Old 10-09-2008 | 08:52 AM
(Mid-Atlantic)
If u already have the yellow top, def do the big 3. I plan to do mine this winter, I have all the wires sitting in my garage
Old 10-09-2008 | 12:22 PM
tegkid's Avatar
spaz
how many feet of say 1 guage wiring would you need for the big 3?
Old 10-09-2008 | 01:07 PM
wong05tsx's Avatar
Need more room in
depends how big your engine bay is, and how you want to run your wires?
Take some string and run it, cut it, measure it, and add an extra foot or so, since the wire isn't as flexible as the string.
You might want to consider kicker hyperflex and/or knukonceptz kollosus fleks for your choice of wiring.. High strand count + flexible + looks good
Old 10-09-2008 | 02:32 PM
(Mid-Atlantic)
1 guage is a bit ridiculous, you don't need more than 4 guage, I used a measuring tape to figure out how long I needed, and bought extra
Old 10-09-2008 | 03:38 PM
ZeroPSI's Avatar
All your base belong to
I use to have 1/0 wire in my car, it was about the most grossly unneeded thing ever. But it was cool to see.
Old 10-09-2008 | 04:10 PM
wong05tsx's Avatar
Need more room in
Stock wire is like a 6ga.. smaller than 4ga but bigger than 8ga.
If you're gonna do the big 3, do it with at least 2ga or 0ga; sinec you're going through the trouble with doing it anyway..
just my
Old 10-09-2008 | 09:52 PM
(Mid-Atlantic)
my stock wires are like 8 guage
Old 10-10-2008 | 02:25 PM
douggiestyle's Avatar
What amp are you running and how efficient is it? I didn't think that the amp draw off 1000 watts is enough to dim lights..
Old 10-10-2008 | 11:24 PM
eleventure's Avatar
Im running an alpine MRP-M1000 and MRP-350. It only dims if I have it at loud vols and it dims even more if I have the A/C on but its not super bad. The the 1000 watt amp should be efficient, its a mono class D amp.
Old 10-11-2008 | 05:27 AM
Costco's Avatar
Big 3
sorry I'm learning so bear with me, do you add another ground from the batt. - to the chassis, or upgrade to a thicker gauge than stock? Then upgrade the alt + to batt + wire? and then add another ground for the alternator? just wanna be sure, thanks
Old 10-11-2008 | 11:07 AM
Trew's Avatar
Don't mess with the stock stuff. Just add to the stock wiring.
+1 on the Kicker Hyperflex. They make the best 1/0 wire I've ever seen, period.
Old 10-11-2008 | 11:06 PM
wong05tsx's Avatar
Need more room in
^+1
Electricity takes the path of least resistance; doesn't hurt to have more than 1 route for it
Old 10-12-2008 | 03:49 PM
Rajca's Avatar
wham bam thank you ma'am
i looked at my car (02tl-s) and i saw that one wire from the alternator goes to what looks be like to the engine and it grounds their and the other wire goes to a fuse box, anyone got any pics on how hey did they alternator set up?
Old 10-13-2008 | 02:47 AM
Costco's Avatar
anyone? google turns up results that are a bit vague for me, sorry.
Old 10-13-2008 | 09:56 PM
Rajca's Avatar
i ordered 10feet of 1/0 wire should be enough.
Old 10-13-2008 | 11:11 PM
wong05tsx's Avatar
Need more room in
Oh yeah, sorry I should've mentioned this earlier, get a fuse holder unless you want to risk shorting out the wire and potentially causing ur car to burn down!
Amp size to the wire
0ga - 300amp
4ga - 150amp
Old 10-14-2008 | 12:53 AM
eleventure's Avatar
0ga - 300amp
4ga - 150amp
Although this is not necessary it is recommended. A fuse is only needed for the ALT to (+) Batt. in the case that the wire becomes loose and falls off.
Old 10-15-2008 | 03:04 PM
Rajca's Avatar
what about a 1ga?
Old 10-18-2008 | 08:58 PM
02AEMCL's Avatar
this is what i did, i had some 0ga lying around, so i used that as well as some 4ga.
0ga from alt to chasis
0ga from battery to eng block
0ga from battery to chasis
4ga from throttle to battery
4ga from manifold to battery
i went a bit over board, but i dont have dimming and i did notice my car to have better starting up, better throttle response, and all around better elctrical flow.
if you still have dimming than unfortunately you may have to up the alt. or deal with it.
Old 10-18-2008 | 09:12 PM
Rajca's Avatar
u got any pics of the throttle to the batter?
Old 10-19-2008 | 07:40 PM
02AEMCL's Avatar
rajca i have to find a pic for you. i know that i have one.
Old 10-22-2008 | 04:55 AM
Rajca's Avatar
i made a diy for the big 3 set up
https://acurazine.com/forums/showthr...1#post10112212
Acura604
2G RDX Photograph Gallery
17
02-08-2021 03:32 PM
Jinkazetsukai
11-21-2015 05:28 PM
Froid
09-27-2015 06:16 PM
Quick Reply: Big 3??
