Amp Problem
Old Apr 9, 2007 | 05:44 PM
spencer_homer's Avatar
i like acura
Amp Problem
i just installed my L7 and kenwood amp, and its been killing my battery. I thought it was a bad ground connection becasue it only dies if it sits over night, so its not that big of a draw. when i unplug the amp, it doesnt die. Anyone know what it could be?
Old Apr 9, 2007 | 06:05 PM
Rapmaster0's Avatar
Do you wire the power on wire to the amp to be CONSTANT? Or is it wired to something like the cigarette lighter that only powers on when the key is in?
Old Apr 9, 2007 | 09:29 PM
uncald4's Avatar
Former Sponsor
The amp is not hooked up right. Or your connection at the battery is very loose.
Old Apr 15, 2007 | 04:57 PM
i like acura
its not my battery, becasue i unhooked the amp and it stopped dying. could it be a short in my amp?
Old Apr 15, 2007 | 05:00 PM
daicacharco's Avatar
CAPACITOR FTW <--------------
also check the wires .. what guage wire you running?
Old Apr 15, 2007 | 07:51 PM
i like acura
4 guage. i feel like a moron, becasue ive been putting this off all week, today i finally went out there and checked it out, and it was a blown inline fuse on my power wire.
Old Apr 23, 2007 | 07:08 PM
i like acura
well thats defiantely not the problem. my battery still dies when my amp is hooked up. Anyone know what could be wrong. My ground is good, my battery cables are tight, and all fuses are good.?
Old Apr 23, 2007 | 09:03 PM
your suppose to wire the remote wire to the ciggarite thingy or something that turns on wehn you turn on your car.
i believe that you tapped the remote wire into a wrong line.
what i did wiht my TSX is that i tapped the ignition wire into one of the wires that is connected to the ignition.
Old Apr 24, 2007 | 12:37 AM
i like acura
no its not my remote wire. i have that wired to an actualy remote wire on my deck.
Old Apr 25, 2007 | 05:01 PM
misterdannyboy's Avatar
check the voltage on your remote wire to make sure thers no power going when your car is off..
Old Apr 25, 2007 | 05:04 PM
joerockt's Avatar
Just dial 1911
Sure you didnt swap the power and remote wires on the amp?
Old Apr 25, 2007 | 05:55 PM
i like acura
u mean like mix them up?
Old Apr 25, 2007 | 07:46 PM
joerockt's Avatar
Just dial 1911
Yea, did you check to make sure the power line isnt in the remote? If it is, that would leave the amp on 24/7...At least I think it would.
Old Apr 26, 2007 | 12:11 AM
i like acura
no im sure that its in the right spot
Old Apr 26, 2007 | 10:06 AM
joerockt's Avatar
Just dial 1911
Well, its a good thing you double-checked
Old Apr 26, 2007 | 11:52 AM
Castles_Saloon's Avatar
spencer homer,
Do you have a digital multi meter (dmm) or ammeter?
If so, there's a few things to measure. The current draw, input voltage (battery) at the amplifier, and Remote ON voltage in the following states
1) the car is off
2)ACC is on, stereo off
3)ACC is on, Stereo ON
If you're blowing fuses then thats a big indicator that an excessive amount of current is being drawn.
The current draw can be measured by doing the following. Disconnect the battery to amplifier connection (positive side). Connect the battery side of the wire to the DMM's amps(current) + input (designated by red color) and connect another wire from the amplifier batt+ to the DMM's amp - input. Now the DMM should be connected in series with the battery line to the amplifier.
BATT (+)->DMM(amp +)->DMM(amp -)->AMPLIFIER (BATT+)
How to interprete?...
The remote ON voltage should be near 0V in states 1 & 2 and close 12v in state 3.
(look at your amp's spec to find out what the appropriate remote on and off voltages are)
If you see current when the car is off (0.1 Amps and higher), that could be bad sign. Verify the remote ON voltage is close to zero. If the remote ON is high (close to battery voltage ~12V), the your remote signal is improperly high. If the remote on is low (~0V), then your amp seems like the problem.
What current do you see when the amp is operating 'normally' (radio on, but zero volume? if this is high, then again this could be another sign that your amp is bad OR is just really power inefficient.
Good luck
Old Apr 26, 2007 | 05:35 PM
i like acura
my dad seems to think that the amp has a short of some sort.
oh theres an voltometer on the amp, and when its on, with the volume down its gettin about 12.4 volts
Old Apr 26, 2007 | 05:44 PM
When the car is off, is the amp on. does the voltmeter read a number and if so, what value?
Old Apr 26, 2007 | 07:44 PM
i like acura
no, when the car or deck is off, the amp isnt doing anything. its off
Old Apr 27, 2007 | 11:11 AM
the amp could still being pulling current from the battery when 'off'. if your battery is weak/old, then that might just be enough to kill it.
your sound system may be fine, but just need a new battery.
if you have a voltmeter, you could check the battery voltage when
1) car is off
2) car starting
3) car on
below 12V in state 1 is getting weak. If in state 2 its below 10V, then you may need a new batt. state 3 shows the alternator voltage is working properly. probably close to 14V. If this is low, then your alternator is not charging your batt properly.
Old Apr 27, 2007 | 06:52 PM
i like acura
well my battery is new, and my car doesnt die when the amp is not hooked up. at first i thought it was a bad ground. but i re made that a couple times. so i dont know
Old Apr 27, 2007 | 06:54 PM
joerockt's Avatar
Just dial 1911
Sounds like you just need take it to a shop and get it done right.
Old Apr 27, 2007 | 08:19 PM
dreem1er's Avatar
deal with it
why don't you go check out the alternator and see if its not charging the battery enough when the car is on....if its not charging the battery completely then it could explain why the car is dying...as for the amp pulling the power...no amp should do that useless the amp is staying on once the car is off.....check all your wires and see if something is loose......other than that......
Old Apr 28, 2007 | 04:10 AM
i like acura
it is done right. and its not my alternator becasue ive had the amp unplugged for 5 days and the car is running fine. my ground is good, everthing is hooked up right
Old Apr 28, 2007 | 11:48 AM
smokendsm's Avatar
ridin slow'n'low
Seriously...it does sound like you tapped into the wrong wire. The chances of that are much higher than a faulty amp.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
