1999 Acura TL wiring questions for sub hook up....
I was going through my engine bay and also from the inside and Im having problems with wanting to get my power amp wiring from the back into the engine bay. I dont see a whole i can slip it through to get to the battery. Anyone encounter this problem and know how I can do it?
Thanks,
Johnny
Thanks,
Johnny
I keeps it real
1 Post
Thanks,
Johnny
Thanks,
Johnny
There is a pic of the hole posted in a DIY somewhere around here. I'll try and find it for you.
I keeps it real
1 Post
Check this thread for help with the install on a 99
https://acurazine.com/forums/audio-video-electronics-navigation-22/need-help-advice-anything-adding-sub-185395/
Check this thread for pics of an install on a 2nd gen CL
http://silverknight.clickhere2.net/sound.html
The pic below shows the location of the firewall hole. Hope that helps
https://acurazine.com/forums/showthread.php?t=185395
Where exactly is that hole located? Assuming its on the drivers side where the pedals are. It looks like its where the emergency brake lever is. Am I correct?
I keeps it real
1 Post
Nope, its closer to the console side of that area, so opposite the emergency brake. The club looking thing you see is the top of either the brake or gas pedal, i dont remember. But either way, just look up inside that area and use the club as a guide to determine the relative location of the hole. I think its covered by up by the rubber shroud but there is a circular cut out indicating the hole beneath. Just poke your finger through the cutout to get to the hole and you're in.
Ill check that out tomorrow. Ill keep you all posted.
I tried to get though the hole also. It is above the gas padal. I could not force the wire through. I ended up going though the window wiring for the driver door. Then I taped up the areas that would not fit with the power supply running through.
Soul_Deamon
11-13-2018 04:44 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
NewtoAcura11
09-28-2015 04:40 PM
