12' W6...wut amp?
Old Mar 24, 2004 | 12:29 AM
babyloc86's Avatar
12' W6...wut amp?
i had 12 w6 and Jl 250/1 amp ...my friend had 12' W3 and had rockford 2 channel amp dunno wut model or wut watt but it wuz 2 chan amp dat he bridged in his integra...wow his sub hited like 3-4x harder den mine..i changed my mind and sold mah JL amp...now wut amp should i get? mono or 2 channel amp and which one? does anyone know which rockford amp will make mah sub hit much harder den mah JL 250? any suggestion guys?
or should i get same one as mah friends?
Old Mar 24, 2004 | 01:52 AM
BoostedM3's Avatar
Bagged hybrid
is that a 12w6v2? i had mine powered off a 500/1.
is your & your friend's sub sealed/ported/bandpass?
Old Mar 24, 2004 | 02:12 AM
DanMan1464's Avatar
Autobot
you probably underpowered it...
you should get at least 500 RMS on it....I have 460 RMS in my solobaric 12 w/ ported box...hits VERY hard....
Yeah get a 500/1 JL mono amp....that would do very nice
Old Mar 24, 2004 | 09:31 AM
Nicky Pass's Avatar
Fuct in the hed!
500/1....they are usually under rated. I've heard that the 500/1 actually puts out around 600 watts!
Old Mar 24, 2004 | 10:03 AM
dets's Avatar
2004 Euro Cup Champions
Nicky, mine is extremly reliable clear and loud. ITs a great product.
Hey babyloc, why are you posting the same thread in to different sections? Stop wasting A-CL's space, its bad enough with ramblings.
Old Mar 24, 2004 | 10:09 AM
evilstorm's Avatar
id also go with the 500/1...jl makes some wicked mono amps. i need to get my hands on either 2 500/1 or 1 1000/1
Old Mar 25, 2004 | 12:11 AM
babyloc86's Avatar
but then again 500/1 amp is so expensive! itz like 400-500$!!
i only have around 300$ to spend on my amp.
Old Mar 25, 2004 | 08:42 AM
evilstorm's Avatar
you need to look around then....im sure you can fnid a 500/1 on ebay for less $300 or right around there....
Old Mar 31, 2004 | 08:37 PM
brado's Avatar
new wheels = old school
you can get a rockford fosgate power amp, the 501bd, which is the better series of rockford products for 265 at infinitecaraudio.com. it def puts out 500 watts because when i recieved mine, it came with a certificate that said it got tested at 532 watts. it is in your price range and is a great quality amp for the price.
Old Mar 31, 2004 | 11:38 PM
babyloc86's Avatar
300 watts RMS x 1 at 4 ohms
500 watts RMS x 1 at 2 ohms
datz the specs of rocford 501bd
my 12' W6 is 6ohms or something....can someone explain how this 12 W6 watt works...will dis amp power 300watt on my W6 or 500 watt??
Old Apr 1, 2004 | 08:22 PM
916CL's Avatar
you can compete with a integra because anything hits hard in the integra because it is a hatchback and the car itself acts like a big box
Old Apr 3, 2004 | 07:18 PM
babyloc86's Avatar
i guess so...but den again, his wuz hitting about 3x harder den mine, shaking my hair n my body while mine juss bumps and shakes my body little bit
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
