TLX Rain Sensing Wipers not Working!
Old Sep 13, 2014 | 03:51 PM
Jazzyguy's Avatar
I just took delivery of the TLX TECH yesterday. Fantastic car. Love every nuance of this car and in the process of discovering more.
One discovery... It seems the Auto Rain Sensing Wipers are not working. Raining today quite hard at times, I have the wiper shaft in "Auto" and set to the highest sensitivity. It won't swipe the windshield once today, not one time. Can't see out of the windshield until I switch it on.
Is there anything I can check myself before bringing it in? I'd rather work on the car myself before letting them touch it. I've read I can pop the camera cover off behind the rear view mirror to check the connector but I can't seem to get it off.
Any insight would be greatly appreciated.
Old Sep 13, 2014 | 04:06 PM
smoooov's Avatar
It's under warranty. Take it in and get a loaner!
FWIW my auto wipers work great so something is wrong.
Old Sep 13, 2014 | 04:25 PM
BandwidthExceeded's Avatar
I agree, i would just bring it in. But I also am a big baby about that stuff, if its under warranty I want them to fix it so they are responsible, not me.
Old Sep 13, 2014 | 05:02 PM
Jazzyguy's Avatar
I guess I probably should. If it's simple enough like plugging in a connector I'd rather be the guy messing around in there. I'm a little anal that way.
Old Sep 13, 2014 | 05:06 PM
Stew4HD's Avatar
You'd rather try to fix it yourself and possibly void your warranty if it affects the ECU? The ECU controls that system. FYI.
Don't chance it.
Old Sep 13, 2014 | 05:08 PM
Ken1997TL's Avatar
It's a connector, not the damn ECU. He's not going to get his warranty voided. Sheesh.
Old Sep 13, 2014 | 06:18 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
It is possible there there is some reset sequence to get it to work again (I am sure the shop manual has it). The question to ask the dealer is whether the windshield was replaced before the car was delivered... suspicious!
Old Sep 13, 2014 | 08:45 PM
Stew4HD's Avatar
Excuse me for trying to protect the OP. Sheesh is right
Old Sep 16, 2014 | 12:20 PM
golftro's Avatar
We had a huge rain storm and my 2 week old Black TLX auto wipers did not work. I turned it into the dealership repair dept today to get them to fix it. We'll see, not happy about it.
Old Sep 16, 2014 | 02:50 PM
Stew4HD's Avatar
I hope it is a quick fix and you have her back ASAP
Old Sep 17, 2014 | 11:09 PM
Rocketsfan's Avatar
FYI, a few days ago, my TLX was caught in a bit of a rain and the rain-sensing wiper feature did seem to work.
Old Sep 17, 2014 | 11:21 PM
Quandry's Avatar
Maybe a dumb question assuming that it is a Tech or Advance model which has the auto feature. Did the wipers work in manual mode? What about the washer or mist functions?
Old Sep 18, 2014 | 06:23 AM
golftro's Avatar
Yes, those functions did work.
Old Sep 18, 2014 | 07:14 AM
Jazzyguy's Avatar
Golftro,did your dealer resolve the problem? I'm curious as I'm having the same issue.
Old Sep 18, 2014 | 08:27 PM
golftro's Avatar
I called today and they said it works fine after they tested it with a spray bottle. I had it on auto and adjusted the sensitivity like the manual said and it didn't work so when I pick it up tomorrow I'll dig for more info. Mine is in the shop due to bad transmission, I pray you don't have this problem: https://acurazine.com/forums/fifth-generation-tlx-2015-415/did-anyone-notice-low-speed-jerkiness-knocking-sound-transmission-917591/page2/#post15165285
Old Sep 22, 2014 | 06:17 PM
Jazzyguy's Avatar
So I finally took my car in to get the wipers checked out. Sensor wasn't plugged in correctly from factory but they also said there was an air bubble in the sensor as well. Part is ordered.
Some of you asked why I was hoping to solve the problem myself... Scratched camera cover, grease on the headliner, scratched/scuffed up interior door panel. Why mechanics refuse to open the door all the way before getting out of the car and scraping their boot all over the door panel completely escapes me! This happens all the time.
Pictures of above sent to service manager. We'll see what happens. I'm insisting on a replacement interior door panel. They need to f#%^ing learn!
Old Sep 24, 2014 | 10:20 PM
nab0610's Avatar
Mine doesnt work either drove about 5 times in the rain today. I changed the sensitivity from high to low and back and got nothing. The wipers worked fine when i manually adjusted them though.
Old Sep 25, 2014 | 07:08 PM
golftro's Avatar
It sucks but take it into the dealership. They got mine working and also other extras turned on too like the A/C automatically adjusting when the car drives into the sun. I read about it before buying the car but never noticed it not working.
Old Sep 25, 2014 | 07:11 PM
golftro's Avatar
Wow that sucks! When I got mine back I could smell stinky worker in mine. After I wiped the seats with a damp towel it went away. I'd stay on them, I hear the dealerships get money from Acura corporate for the work they do on cars under warranty.
Old Sep 26, 2014 | 07:51 AM
miner's Avatar
Just wondering if you guys have your Auto wipers set for rain sensing vs intermitent. I think that is in the Setup mode. For rain sensing the setting is a bit confusing, I think. Is more sensitive set on the single drop indicator - that is how I read it in the manual?
Old Sep 26, 2014 | 08:34 AM
Quandry's Avatar
For models that have rain-sensing wipers there is only one position for auto and intermittent, and I have not found anything under Settings related to this.
The confusions come in when the manual has to cover the variations between models that have the feature and those that do not. So from the manual for Auto adjustment, a single drop setting is less sensitivity (requires heavier rain to activate), and multiple drops is more sensitive (requires less rain to activate). This is counter intuitive to the icons and the Intermittent usage. I will have to verify the next time it rains.
Old Sep 26, 2014 | 12:42 PM
joeddmd\'s Avatar
I reported the auto wiper problems back on August 11th. I'm still having them. Basically, when it rains the sensitivity is very low to none at all. IE, they don't run in hard rain. Oddly enough, after raining, the next time I drive the car the wipers will run at a high speed while on auto, even though the windshield is dry. I'm thinking a connection may have been reversed. I don't want someone at the dealer pulling things apart and breaking clips and fasteners, so I'm going to wait till my next oil change. Hopefully a tsb will be out by then.
Old Sep 27, 2014 | 12:04 AM
Living in the Seattle area it did not take me long to test this feature. Mine is working, and for the first 20 minutes of the drive it went very well. In Auto I could twist the selector to choose how much rain it would allow to be on the windshield.
However as Seattle does, it sprinkled for a while and then stopped. My wipers did not however. Not only did they not stop, they went on fast mode and were wiping across a dry windshield for at least 45 seconds, so I turned it off.
Considering I was driving someone around to show the car off to them, it was a bit annoying, but I would rather have oversensitive than not working at all.
Old Sep 27, 2014 | 05:47 PM
ShiftinAt8600's Avatar
This. I've noticed you have to put it DOWN a notch (intermittent position) from normal position and the switch turned to auto for it to work. Try it and see if it works.
Old Oct 24, 2014 | 01:45 PM
EE4Life's Avatar
Forum Contributor
Issue mentioned in the 2015 Acura TLX One-Pack Update #11
https://acurazine.com/forums/fifth-g...iative-916999/
Old Nov 14, 2014 | 11:49 PM
JetDriver's Avatar
I'm completely with you, Jazzyguy. 98% of the cosmetic damage that happens to my cars happens when I take it in to the "professionals." I've learned to do an awful lot of stuff on my own, and will always try to figure it out on my own before I'll take it in. Speaking of which, does anybody know if maintenance service manuals are available to the public? My salesman said he'll check for me, but as he doesn't have my car yet, I have no answer.
Old Nov 15, 2014 | 12:47 AM
Davinci547Acura's Avatar
Automobile service manuals are normally available to be public for $ from Helms, the same company that provides printed owner manuals for TLX. I would contact them for availability. However since Acura has been reluctant to provide comprehensive printed manuals with the car when purchased and opted for a CD instead, the service manuals could possibly be on CD also since so much stuff is being updated on the car and probably with much more to come.
BTW many customers still don't know printed owners manuals are available free of charge because sales people don't tell them when car is purchased and owners do not read the fine print on page three of the abbreviated booklet that is provided.
Old Nov 15, 2014 | 02:16 PM
Linmk2's Avatar
You are correct. I was a comptroller for a number of car dealerships for 22 years, including an Acura store. The factory does pay the dealership to perform warranty repairs, both labor and parts.
Old Nov 17, 2014 | 11:11 AM
bdwpac81's Avatar
I have the exact SAME frustrations every time I bring mine to the dealer... it always comes back with a new scuff, scratch, or grease mark somewhere. The surveys are completed accordingly but nothing seems to change.
Old Sep 6, 2015 | 04:12 PM
EE4Life's Avatar
Forum Contributor
https://acurazine.com/forums/problem.../#post15545835
Old Apr 4, 2016 | 10:47 AM
novs25's Avatar
on my 2016 advance sh-awd model, i noticed the automatic wipers would not engage unless i put pressure on the sensor box under the mirror. Taking it into the dealer on wednesday
Old Sep 13, 2016 | 09:31 PM
cube1's Avatar
Just as an FYI to add to this thread, the auto sensing did not work on my wipers right off the lot (it rained that day). After a second day of rain to verify it, I took it in today. They indicated that it had "not been installed correctly" - read that to mean that the wires were not connected (I specifically asked). Several posters here have indicated that same issue.
csmeance
Jan 7, 2026 06:25 PM
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
acurajj
Sep 19, 2015 03:47 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
