Transmission Fluid Change
Old Apr 26, 2012 | 10:41 AM
Duna's Avatar
Hello everyone,
I searched the forums and did not see any detailed information on how to drain and fill instruction on the forums. I recently change the oil and I had a hard time locating the transmission drain bolt.
If someone is kind enough and let me know where the bolt is located, it would be much appreciated. Furthermore, I saw a youtube video of a 3g tl transmission fluid change and this person unbolted a fill bolt of the car as well. Do we need to do that as well on our cars?
Thanks.
Old Apr 29, 2012 | 12:21 AM
ShadeTreeMech's Avatar
From Chilton Manual:
Drain & Refill
  1. Warm up the engine to normal operating temperature (the radiator fan comes on), and turn the engine off.
  2. Raise the vehicle on a lift, or apply the parking brake, block both rear wheels, and raise the front of the vehicle. Make sure it is securely supported.
  3. Remove the ATF filler bolt and drain plug, and drain the Automatic Transmission Fluid (ATF).
  4. Reinstall the drain plug with a new sealing washer.
  5. Refill the transmission with the recommended fluid through the filler hole. Always use Acura ATF-Z1 Automatic Transmission Fluid (ATF). Using a non-Acura ATF can affect shift quality.
  6. Install the ATF filler bolt and a new sealing washer.
  7. Check the ATF level.
  8. If the maintenance minder recommends replacing the ATF, reset the maintenance minder, and this procedure is complete. If the maintenance minder did not recommends require you to replace the ATF, go to step 9.
  9. Connect the HDS to the DLC located under the driver's side of the dashboard.
  10. Turn the ignition switch to ON (II), or press the engine start/stop button to select the ON mode. Make sure the HDS communicates with the PCM. If it does not, go to the DLC circuit troubleshooting.
  11. Select BODY ELECTRICAL with the HDS.
  12. Select ADJUSTMENT in the GAUGE MENU with the HDS.
  13. Select RESET in the MAINTENANCE MINDER with the HDS.
  14. Select MAINTENANCE SUB ITEM 3 RESET, and reset the ATF life with the HDS.
Old Apr 29, 2012 | 07:53 AM
Duna's Avatar
Drain & Refill
Thanks bro... I found the drain plug under the car the other day. It has a special looking bolt on it. I can just fit a 3/8 wrench into it. I love the fact that the transmission bolt is easily assessable. Thanks!
Old Sep 24, 2013 | 12:42 PM
deepblue626's Avatar
where is the filler hole??
Old Sep 24, 2013 | 05:49 PM
jim_c's Avatar
Scary.
AntSauce's Avatar
At how many miles are you changing your ATF?
Old Sep 24, 2013 | 06:45 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
When you see the number 3 pop up in you maintenance minder, among other numbers and letters. Filler hole is on top of the transmission, you can't miss it, its the biggest of all in that area, next to the two coolant tubes and that big black plastic electrical wire cover.
Old Sep 26, 2013 | 09:47 AM
Mr Marco's Avatar
Holy shit
I'd recommend you find the hole first before you drain her!!!
Old Sep 26, 2013 | 09:58 AM
jim_c's Avatar
As someone once said, "sometimes DIY is not a good idea"!
Old Oct 5, 2013 | 10:24 PM
arek1200's Avatar
Drain & Refill
what is DLC,HDS,PCM ?
Old Oct 5, 2013 | 11:33 PM
Edward'TLS's Avatar
6G TLX-S
HDS is the Honda diagnostic tool.
DLC is the rectangular diagnostic connector (located under the driver's side of the dashboard) that the HDS cable plugs into.
PCM is the engine controller.
Old Oct 6, 2013 | 01:34 PM
arek1200's Avatar
Can this be done with other diagnostic tool than HDS?
Old Oct 9, 2013 | 09:19 PM
arek1200's Avatar
Can transmission be refilled through a dipstick tube?
I guess it can....it would take a little bit longer than through filler bolt...
Correct me if I am wrong...
Thanks.
Old Oct 17, 2013 | 06:50 PM
Reorge's Avatar
I filled my one time when I couldn't find my 1/2" extensions to remove the filler bolt. Horked my wife's small funnel from the kitchen, she never missed it. It worked but took more time than I had patience for.
Old Aug 31, 2014 | 04:12 PM
antlive's Avatar
Cruiser
do you do the 3x3 for 4th Gen?
Old Aug 31, 2014 | 05:11 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
You can.
Old Aug 31, 2014 | 05:17 PM
antlive's Avatar
Cruiser
Originally Posted by princelybug
You can.
the question is, is it necessary. I just did 2x3 and I'm going to evaluate it after a day.... I do the 3x3 on my 07 TLS, but I drive it hard.....
Old Aug 31, 2014 | 06:55 PM
It's not "necessary", but preference. If regular drain/fills are being done, a 1x3 should be fine.
Old Aug 31, 2014 | 07:57 PM
acupower's Avatar
I did a 3x3 when I got my 4G at 65k. The ATF that was in there had a decent color (not too far from brand new).
I went to the dealership and spoke with one of their mechanics. He said that they do the following as a standard procedure at 35k miles:
1. Check ATF and if its color is way off (darker and less transparent than new) they would do 3x3. Otherwise, they just do a 1x1.
2. Replace transfer case gear oil and differential fluid.
I plan to be more conservative. I'll be doing a 1x1 on every second engine oil change (i.e. every 10k or so).
Old Aug 31, 2014 | 08:04 PM
acupower's Avatar
Drain & Refill
This is not the complete procedure...I recommend you download the Acura Service Manual (you can find it in this forum) and follow their procedure.
It is very important that you take a hot reading. That means you idle the car until the coolant fan comes on. Then you turn it off and WITHIN 60 to 90 seconds you check the ATF dipstick level. It should be between the two lines.
Also, Honda has discontinued the Z1 fluid because it was crap. They now only sell the DW-1 fluid which is a synthetic blend and is much better.
Old Sep 1, 2014 | 05:54 PM
arek1200's Avatar
How much fluid does it take to bring it from minimum to maximum level on the dipstick?
Anyone..?
Old Sep 1, 2014 | 06:04 PM
acupower's Avatar
Anyone..?
It depends on how much fluid you've drained. If the car was on level ground, you could drain around 3 quarts so it would take roughly 3 quarts to bring the fluid between the lines.
You could always collect the drained fluid and measure how much it is and then refill the same amount. But even then, you should still follow the recommended procedure and do a hot reading.
Old Sep 1, 2014 | 07:21 PM
arek1200's Avatar
Yes, the hot reading is mandatory....
just wondering why is there a specific time frame given (60-90 seconds)after the engine is shut off ?
What happens after that period...?Is the fluid level changing due to temperature /volume change and making the reading inaccurate??
Old Sep 2, 2014 | 02:52 PM
jim_c's Avatar
There is ATF in the transaxle and its reservoir (in the case itself) and in the torque converter.
You want to measure (read) what is in the transaxle, available to the trans oil pump under operating conditions. If you wait a while (too long) after you shut off the engine, the oil (ATF) from the TC will start to drain back into the trans and you will get an OK reading when there is actually too little oil, or you will get an apparently high reading when the amount is actually correct. Most cars used to call for checking the ATF level with the engine running for this reason.
Old Sep 2, 2014 | 07:55 PM
arek1200's Avatar
Makes sense....Thanks.
Old Sep 2, 2014 | 11:27 PM
acupower's Avatar
A lot of people check their ATF level when their car is cold (usually in the morning) and are surprised to find out that the level is way above the upper line. As Jim_c explained, this is caused from the tc draining and is absolutely normal.
Also, don't stress out if your level is just slighly above the upper mark when you do your hot reading. This won't any issues so don't go crazy trying to get it perfect.
Old Nov 7, 2014 | 11:33 PM
Georgiey22's Avatar
Does anyone have a video that can be uploaded to YouTube so we can have a visual of this process? Thanks guys!
Old Dec 28, 2014 | 11:44 PM
Georgiey22's Avatar
This weekend I drained the tranny oil in my 2013 TL FWD and 2012 Accord SE and used the dipstick tube to refill. Both were very easy to do and didn't take much time at all. I'll continue to use this method every 15K miles. Thanks for all the info guys!
Old Feb 7, 2015 | 08:28 PM
vinnier6's Avatar
Just did my 2010 sh-awd, had the front end on Jack stands....drained out 3.5 qts and put back in a little more then 3.5 qts and it still reads at the bottom "hot" mark....service manual says 3qts...
I feel like it needs a little more to bring it between the marks
Old Feb 7, 2015 | 09:35 PM
csmeance's Avatar
When I did the fluid change I also used about 3.5 quarts of Acura DW1 to get it to the proper level. Make sure the fluid is warm when you are checking it and the car is on a level surface!
The Filler bolt on my 2013 was SIEZED!!! Instead I used the dip stick hole to fill via a funnel. Unlike the 2004 TL and 2007 MDX, the dipstick hole is the size of a quarter and any funnel can fit into it easily!
Old Feb 8, 2015 | 07:57 AM
vinnier6's Avatar
Thanks csmeance....the car was pleanty warm sitting on level ground...checked it this morning while it was cold and reading exactly in the middle of the two marks, which is where I want it to read when warm....
Is it possible since I had the front end on Jack stands and the rear on the ground that I drained more out then the book calls for? The service manual says 3qts for a drain and fill on sh-awd ...I know for sure I drained over 3.5qts
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
nanos
Nov 12, 2015 08:41 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
quake97
Aug 30, 2015 07:57 PM
