Replacing turn signal
Old Apr 24, 2015 | 08:27 AM
6SpeedTL's Avatar
Took a rock to the turn signal on the highway and it shattered. Have a new one arriving tmrw. Looking underneath the car its hard to tell if the singal can be pulled out without taking off the bumper.
Has anyone replaced one on a 2013 TL ?
Thanks.
Old Apr 25, 2015 | 02:49 AM
01acls's Avatar
The owners manual will have instructions on how to change all light bulbs on the car.
Below the lamp are 4 10mm bolts and a plastic clip. Take those out and peel back the fender liner to access the lamp socket.
Old Apr 25, 2015 | 11:19 AM
6SpeedTL's Avatar
I need to replace the whole unit not just the bulb.
Old Apr 25, 2015 | 01:30 PM
01acls's Avatar
Sorry my bad. In that case then just look at your new lamp. It will tell you how it's mounted exactly and go from there. If it's mounted from behind just go through the wheel liner from the bottom or the wheel weld. Turn your wheel for clearance.
Old Apr 26, 2015 | 07:41 AM
6SpeedTL's Avatar
Thanks man. Will start there.
Old Apr 27, 2015 | 11:14 AM
6SpeedTL's Avatar
Just for an fyi - It was only 1 - 10mm bolt underneath, once removed it pulls out and new one clips in.
Old Apr 27, 2015 | 12:51 PM
01acls's Avatar
Thank you, nice to know.
Can you tell us how to removed the new clip on lamp, from outside now? I'm sure others would like to know when changing the bulb.
Old May 5, 2015 | 12:31 PM
6SpeedTL's Avatar
You don't remove the clip, it stays in place. Simply pull the old out and push the new in.
Old May 5, 2015 | 03:07 PM
Tekniq's Avatar
https://acurazine.com/forums/fourth-...9-11-a-867595/
mada51589
Jan 9, 2025 04:40 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
