Problem with VSA and ABS
Old Jan 25, 2010 | 01:42 AM
Iceman52489's Avatar
Connoisseur of Aesthetics
Hey guys, so I ran into a pretty big problem the other day. So my "headlight" guru friend decided that he wanted to help me install some new lighting into my car that required tapping into one of the headlight components...aka the turn lights. Anyways, this pretty require us to test wires. So he decided his automatic wire stripper was better than my manual one and decided to accidentally, completely cut the white cable. Is so happens that it was my VSA/ABS wire. I'm not sure how its connected or what exactly it's connected to (power line..? , to wheel sensors?) so I'm hoping one of you guys can tell me.
I re-soldered the connection but don't understand how the error codes work. Do they reset after I have fixed it or no? The location of the wire was in the plastic covering exactly to the right of the battery compartment.
Any tips and advice would be greatly appreciated!
Old Jan 25, 2010 | 11:03 AM
NS-TL's Avatar
Not exactly sure what this pic is supposed to show other than the engine bay and shroud but mybe try disconnecting the battery again and let the car be for an hour or so. If that doesn't work you may have to get the dealer to rid the code for you or a trusted shop. It may clear itself up when it realizes the connection is re-established.
You also should give your buddy a kick in the ass as this could open up warranty issues for you.
Old Jan 25, 2010 | 12:16 PM
tapht's Avatar
+1 (for the ass kicking part)
You may want to consider the dealer replacing the wire completely
Old Jan 25, 2010 | 06:48 PM
The problem is I don't know if I fixed it or not. If I did, would the error code go away or would I have to reset the codes? Do I need a dtc handheld to remove it or could disconnecting th battery work?
Old Jan 25, 2010 | 06:54 PM
dwest1023's Avatar
You cannot hurt anything by disconnect the battery, so give it a try. How do you not know if you connected it correctly or not? If you cut the wire and you soldered it to the other side of the cut wire, it has to be fixed. Unless you blew a fuse somewhere a battery disconnect should be good to go.
Old Jan 25, 2010 | 07:12 PM
How long is a good amount of time to leave it disconnected? Is it positive to be disconnected first or negative?
Old Jan 25, 2010 | 10:43 PM
HiroY's Avatar
I would disconnect the negative terminal from the battery. I don't even think you have to disconnect the positive side, but if you do, disconnect that after you disconnect the negative. Then to reconnect, do the positive first and then negative last. Hope that works for you! I know on my old Honda S2000, certain codes had to be cleared by pulling a specific fuse with some sequence of turning the key/power with the fuse out...dunno if a similar process might apply here. Good luck!
Old Jan 26, 2010 | 12:44 AM
BLACKURA_NY's Avatar
I have car ADD
VSA & ABS lights/codes will go off after you drive a few miles (assuming you fixed it)... like 2-5 miles....
I was doing a few dyno pulls on my car, and i set off all the VSA & ABS lights.... i started to panic, but after about 1 mile, they went off
Old Jan 26, 2010 | 01:26 AM
Oh really...well dealer time. I won't even waste my time then. -_- Thanks guys.
Old Oct 19, 2010 | 01:03 PM
3gacuratl's Avatar
does anyone know how to reprogram the vsa system. i was told that i have to drive at 20mph for a certain time and other speeds but didnt really explain.is any possible way to reset or would i have to take to dealer
Old Oct 19, 2010 | 01:53 PM
Mr Marco's Avatar
Some more information would be helpful. What is wrong with your VSA?
Old May 26, 2013 | 09:41 PM
vtec314's Avatar
Guys same stuff happened to me. I dyno my car, abs , vsa came on, I drove 200 miles and still on, I slammed by breaks and still on, I dont know what to do, I cant take it to dealer, they will avoid my warranty . please help me
Old May 27, 2013 | 11:09 AM
Edward'TLS's Avatar
6G TLX-S
What have you done to your car, that the dealer might void your warranty ?
Old May 30, 2013 | 07:10 PM
vtec314's Avatar
intake, full exhaust system, pre cat deletes
Old May 31, 2013 | 02:03 PM
Edward'TLS's Avatar
6G TLX-S
Put the original stuff back before visiting the dealer, to save your worry.
Old Jun 10, 2013 | 06:56 PM
vtec314's Avatar
I know that, kinda busy now days , do you think I can do something without going to a dealer?
Old Jun 11, 2013 | 02:37 PM
dwest1023's Avatar
did you disconnect the battery as suggested yet???
4drviper
Apr 23, 2025 07:13 PM
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
