P0328 Code: Knock Sensor 1 Circuit High (Bank 1 )
Old Apr 14, 2021 | 05:59 PM
Bobloblaws's Avatar
4th Gear
Hello friends,
Before i try to replace the knock sensor, is there anything else this could be? Also does anyone have a link showing how to replace myself? Cheers
Old Apr 14, 2021 | 07:02 PM
the knock sensor is buried underneath the intake manifold and it's runners...
bad place for a sensor because all the heat from the engine will make the plastics brittle.
remove intake manifold.
remove intake manifold runners.
and you'll see the knock sensor.
it could be broken from the aforementioned heat.
or it could be broken from a rodent.
the only way to tell is to dig right in.
Old Apr 16, 2021 | 06:29 PM
Bobloblaws's Avatar
4th Gear
Originally Posted by Bobloblaws
Hello friends,
Much appreciated Moderator man
mayjarjar
Jan 14, 2019 06:12 PM
dcbakerphoto
2G CL Problems & Fixes
Oct 24, 2016 09:47 AM
onlydoug
Jan 9, 2014 08:36 PM
Mandy
1G TL Problems & Fixes
18
Jun 17, 2011 12:45 PM
