Knocking noise when accelerating
Old Feb 24, 2018 | 07:50 PM
Cooldude01's Avatar
all,
My TL just passed 71k Miles and I've noticed the knocking noise when accelerating. This just happened within the last two months but the thing is it comes and goes.
Sometime the car runs fine but once in awhile i can hear the knocking noise. It bothers the hell out of me.
I will try to look at the spark plugs tomorrow but the car is only 71k Miles. It doesn't make sense to me that any of the spark plugs fails.
The other thing I'm looking into is the low oil pressure. Since the 3.7 Engine burns oil, it could be a problem.
I recently change Mobil1 synthetic oil at 69K Miles.
Has any other member have the same problem???
Old Feb 25, 2018 | 07:59 PM
Anicra's Avatar
Going to say this as a 'catch-all' answer to any noise posted. Seriously after having my ATF filter replaced 2x, I heard a noise that my brain said, 'sounds like a bearing' my neighbor came over after hearing the noise and said the same. I thought perhaps water pump, no it was ATF filter. I heard it at idle and would disappear on higher RPM esp when the engine was cold. Now the second time, they replaced it - it made a gurgling sound, like you expect with fluid. At least I got 2 free tranny fluid changes. I am not saying that is your problem. Just expect the unexpected sound. Though it did not sound like a knock, since I think of poor octane and timing, knocking noise when some says knock.
Old Feb 25, 2018 | 08:46 PM
dopeboy1's Avatar
The inconvenient truth
spark knock?
Old Feb 26, 2018 | 08:43 PM
Cooldude01's Avatar
I thought about that too but the ATF filter was replaced when i had my transmission fluid changed under TSB and this "knocking noise" is intermittent..Only happened when it's cold outside .. so far.
Old Feb 26, 2018 | 08:44 PM
Cooldude01's Avatar
Thumbs up
Originally Posted by dopeboy1
spark knock?
That is my guess.. I will try to remove the spark plugs to see if any of them has damages..
I'm doing a search in here to see if there is any DIY for that..
Old Feb 26, 2018 | 09:07 PM
teh CL's Avatar
Could it being the timing tensioner? More of a clicking noise though.
Old Feb 26, 2018 | 09:23 PM
meowmeows's Avatar
Is it the same as this issue?
https://acurazine.com/forums/4g-tl-p...ration-919491/
Old Mar 1, 2018 | 10:03 PM
Cooldude01's Avatar
I'm not sure but it went away when the weather is warming up..
Cooldude01's Avatar
Originally Posted by meowmeows
Dude..that is it ..
Thanks a lot..
Nedd
1G TL (1996-1998)
Sep 20, 2006 02:16 PM
ccannizz11
Jul 16, 2004 09:16 PM
J98CL
Oct 27, 2003 05:33 PM
SicK TypeS
Jan 7, 2003 02:19 AM
AtlCl
Apr 11, 2002 01:24 PM
