Jump Starting the Battery
Old Jan 26, 2014 | 08:59 PM
minsbang's Avatar
Hi All,
I had to pull over to help someone jump start their car and noticed that the negative terminal is impossible to access (I can see it from the small hole, but it's not possible to get the jumper cable to fit in).
Do I have to remove the plastic coverings just to get access to the negative terminal? I hope not. I understand that Acura wanted to make the engine bay look clean and it's suppose to make the noise level low at high speeds, but seems impractical for easy access.
Any input is greatly appreciated.
Thank you in advance.
Old Jan 26, 2014 | 10:26 PM
Samba's Avatar
Any exposed metal part in the engine bay can be used as the negative connection.
Old Jan 26, 2014 | 11:30 PM
Edward'TLS's Avatar
6G TLX-S
According to the owner's manual, the negative jumper cable should clip onto the "engine block metal hanger" located on the passenger side of the engine.
Old Jan 27, 2014 | 05:21 AM
KarKraze's Avatar
I usually use the engine hanger like "Edward TLS" mentioned but it is also true that people will use any other exposed metal part.
Here is a pic of where i use.
Old Jan 27, 2014 | 07:11 PM
minsbang's Avatar
Thank you all for the valuable information. When I had initially tried this, I used the extral metal "piece" that was sticking out once I removed the positive terminal casing. Perhaps i should have been a bit more patient with the transfer of power.
I will try your suggestions going forward.
obert
Dec 14, 2015 11:36 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
jordanboi
Sep 5, 2015 01:33 AM
