When I step on my brakes...
Old Jan 28, 2013 | 08:37 AM
2Feisty4you's Avatar
I have a 4th g TL at times when I step on my brake and then release it I hear a noise. Kind of like a little horn. It doesn't happen all the time. What can it be? I'm new with this help!
Old Jan 28, 2013 | 08:38 AM
like a squeak?
Old Jan 28, 2013 | 08:44 AM
like a squeak?
Yes, like a squeak. Brakes maybe I need to change? But my brakes feel fine. Would something be in the way?
Old Jan 28, 2013 | 08:48 AM
when does this do this?
after the car has been sitting?
after the car has been sitting and you reverse?
on the freeway?
applying the brakes with light pressure?
applying the brakes with heavy pressure?
Old Jan 28, 2013 | 08:58 AM
Im not 100% sure, the last time was I started the car. I warmed it up, drove three blocks to my destination. Then left it running, for ten minutes. About to take off and I put it in drive and I hear the noise.
Old Jan 28, 2013 | 07:39 PM
VQPower37's Avatar
my brakes do a similar thing ... its only in the morning, may just be some frost on ur rotors and when they heat up they should be good ... if not, how many miles are on ur brakes ... maybe time for some new pads?
Old Jan 28, 2013 | 09:32 PM
vinnier6's Avatar
what kind of miles are we talking about on the car
Old Jan 29, 2013 | 05:28 AM
I bought the car few months ago. Not sure when the previous owner changed it. How often should I change the brakes?
Old Jan 29, 2013 | 07:47 AM
vinnier6's Avatar
it sure would help is you would tell us how many miles are on the car
Old Jan 29, 2013 | 08:45 AM
fsttyms1's Avatar
Where do you hear the noise, like where is it coming from? When you release the brake is it a sound inside the car, out side? Front, Rear, Left, Right?
Old Jan 29, 2013 | 10:18 AM
dwest1023's Avatar
Have your brakes check. They are probably worn and you are hearing the low brake pad sensor disengaging from the rotor.
Old Jan 27, 2014 | 07:19 PM
minsbang's Avatar
i'm hearing the same noise from my '10. The brakes are fine but will have to see if the noise continues when it gets warmer. I recently purchased it last year towards the of November. I don't recall it making that noise at first, until the temperature had dropped. Perhaps it is the temperature that's contributing to the noise.
Old Jan 28, 2014 | 12:54 AM
potmilkz's Avatar
brake fluid?
Old Jan 28, 2014 | 05:43 PM
JasonK's Avatar
09 TL SH AWD /w TECH
It could be a number of things.
Check your brake fluid should be clear and if it's old it'll turn brownish if so needs to get replaced.
Also might need new brake pads.
There is never an amount of time where you need a brake job. You need to change out the pads every once in a awhile unless you brake hard on your brakes a lot then your looking at a brake job every half a year or less that means new rotors and pads.
I suggest when buying a new car to ask when the last service for brakes was done and if it was a long time ago and the brakes feel like they need to be changed out I would go ahead with that.
That's one thing on a vehicle you don't fuck around with. Brakes, Tires and Fluids.
tsx_boy
Dec 13, 2019 08:33 PM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
DerrickW
Nov 15, 2015 05:52 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
