Ghost puddle lights problem/electrical issue maybe??
Old Apr 16, 2015 | 09:55 AM
chrissalvatore's Avatar
Unhappy Ghost puddle lights problem/electrical issue maybe??
So I purchaces these Acura projector ghost light sfor my 2 front doors.
Amazon.com: XtremeŽ 5w 4th Generation 2x LED Car Door Laser Projector Ghost Shadow Step Light Logo for Acura: Automotive Amazon.com: XtremeŽ 5w 4th Generation 2x LED Car Door Laser Projector Ghost Shadow Step Light Logo for Acura: Automotive
Last night I started the install. I decided to cut the current wires to the factory door light and just connect the two wires to the ghost lights since I wont be using the factory lights anymore.
After the drivers side ghost light was installed it worked for like 2 minutes then went out. I decided to test the passenger side which still worked, installed the ghost light into the passenger door and again, it worked for 2 minutes then nothing.
I then reattached the factory lights and now those dont turn on????
I thought maybe a fuse, but wouldnt all of the interior llights go out? I thought one fuse ran through all of the interior lights. Any help would be appreciated.
Old Apr 16, 2015 | 10:48 AM
KarKraze's Avatar
Did you use the original wires from the puddle light? IIRC the ground comes from the MICU and does not have enough power for the LED lights, highly likely that you damaged the MICU. I am no expert so someone else with more knowledge can chime in. I have read of other causing the same damage.
I did the lighted door sills on my car and used a constant + from the battery and the floating ground from the door pin switches.
Old Apr 16, 2015 | 10:53 AM
Yes, i used the wires from the puddle lights. Damn. Any idea on a fix for this?
Thanks KarKraze
Old Apr 16, 2015 | 10:58 AM
KarKraze's Avatar
To my knowledge, no. Only to replace the MICU. Again, hear from others as this is only my theory on what happened.
Old Apr 16, 2015 | 10:59 AM
potmilkz's Avatar
this happen to a fellow member... he had to bring his car back to the dealer to replace an entire fuse box because there was no way to get the light to work again. fusebox was damaged somehow per dealer.. it was covered under warranty.
best of luck.. next time.. disconnect the battery before you do anything.. although its not required.. its preferred..
Old Apr 16, 2015 | 11:19 AM
KarKraze, can you let me know wher exactly you ran you pos and neg wires.you said you used a constant + from the battery and the floating ground from the door pin switches. Did you run two seperate wires straight to the battery? And where can I find the Door pin switch?
Maybe I can go your route since the only thing not working is the OEM door lights ( which I was going to disconnect anyway). If I dont have to replace the MICU I wont. But I did see it was available online for around $140.00 US dollars.
Thanks again guys. Looks like it was a dumb mistake.
Old Apr 16, 2015 | 11:28 AM
KarKraze's Avatar
I have an aftermarket amp which feeds + directly from the battery. I tapped in to that for the constant positive.
The door pin switches are on the door column (small black rubber covered switch on the car body) it has a floating ground, meaning that the circuit is completed when the door is open only. It is screwed in with two bolts / screws, open them and trace the wire to see the colour. Make sure you use a tester , as you depress and release the pin switch you will see your tester light go on or off.
Before making any final connection disconnect your battery.
Old Apr 16, 2015 | 11:29 AM
Thanks KarKraze, I'll try that tonight. Acurazine is the BEST!!!!!
Old Apr 16, 2015 | 11:43 AM
KarKraze's Avatar
You are welcome, be careful though at least it just the door puddle lights that are gone.
Let us know how it goes, it can help others.
Old Apr 16, 2015 | 01:26 PM
I also reached out to User Error, since he had the same issue. Pretty sure he was able to do what you explained, after frying his MICU puddle light portion.
Old Apr 16, 2015 | 07:09 PM
I emailed Amazon and told them the the directions to install these ghost lights on our vehicle were incorrect. Left it in their feedback. Here's what I got back.
ear chris salvatore,
Thank you for submitting feedback on your Amazon Marketplace order. We regret to inform you that your recent feedback has been removed. We highly value customer input, however we occasionally remove feedback that does not meet our feedback guidelines. Please take a moment to review the details of the removal below. You may then choose to revise and resubmit your feedback.
We appreciate your understanding.
Your feedback comment:
Purchase these light already, thought I messed up the first pair so I ordered another (which I cancelled) But upon further inspection these lights will not work on the Acura TL as advertised. The current/ground supplied to the door bulbs is not enought power for the LED and will result in a blown MICU which will end up costing you hundreds to replace.Will end up wiring a different way.
Reason for removal:
Feedback submitted was a product review and not related to seller.
Old Apr 17, 2015 | 11:09 PM
real_mckoy's Avatar
this also happened to me when i was replacing my bulbs with oem recommended replacements... members said check the wiring, check the fuse, do a electrical test.. nothing work and no one has came up with a real service solution unless we take it to the dealer and pay for the service, hopefully someone can come up with something so that we can all reference this fix. Quite a few members have experience this problem.
Old Apr 18, 2015 | 02:53 PM
Thumbs up
Thanks to KarKraze and UserError for the help in completing this project. I think the lights look awesome. I've already gotten numerous compliments on them.
Attached Thumbnails Ghost puddle lights problem/electrical issue maybe??-20150417_193645.jpg   Ghost puddle lights problem/electrical issue maybe??-20150417_193735.jpg
Old Apr 18, 2015 | 03:26 PM
Edward'TLS's Avatar
6G TLX-S
How did you fix the problem ?
Old Apr 19, 2015 | 08:19 AM
I just ran the power wire from the positive puddle light and the ground to the door latch pin on the door jam. I guess I just fried the grounds for the oem puddle lights.
Old Apr 19, 2015 | 12:09 PM
KarKraze's Avatar
Yep,that is what happened, you are good with what you did now. Happy to hear that you like the new puddle lights .
Old Apr 23, 2015 | 12:36 AM
real_mckoy's Avatar
i might have to also do this..great work.
Old Apr 23, 2015 | 12:18 PM
Warchild's Avatar
I think that's pretty cool, I might have to pick up a set
Old Apr 23, 2015 | 01:49 PM
potmilkz's Avatar
anyone else think this is tacky?
Old Jul 23, 2022 | 04:54 PM
dee_snutts's Avatar
well, i lost my puddle lights and anything else that is triggered from the door being open. doenst show that the door is open on the cluster, dome lights dont come on, and worst is the alarm doesnt see the door is open. i mainly am concerned about the alarm not being triggered if the door is open. is there a bypass that i can do for just the alarm trigger? what actually need to be replaced to ficx this? oh, also the window down feature that you can use the remote to initiate doesnt work either
Old Jul 24, 2022 | 08:29 AM
Frankyy's Avatar
2014 TL
first thing to do is check all fuses To see if any are blown
Old Jul 24, 2022 | 10:45 AM
dee_snutts's Avatar
ive done that, the window down feature is working or started working after i ran a wire to fix the puddle lights. i think the only issue now is that it doesnt show when the drivers door is open.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
wusty23jd
Sep 24, 2015 11:41 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
Nicho863
Sep 2, 2015 08:12 AM
