Door panel creak...
Old Nov 10, 2010 | 05:02 PM
vinnier6's Avatar
Door panel creak...
how hard is it to take off the door panel?? i need to get behind it to see if i can fix a creak that comes from where you would put your arm if you had the window down while driving...if you push on the trim right above the aluminum piece where the window goes inside the door it creaks...is there a way to fix that....
maybe someone can help me out with some pics
thanks
vinnie
Old Nov 11, 2010 | 11:22 AM
vinnier6's Avatar
not one person took off their door panel?, anyone else have the creaking or popping while pressing on the door trim just above the aluminum trim....
Old Nov 11, 2010 | 01:44 PM
Mr Marco's Avatar
good point. Some of us (me), need to turn down the stereo and start fixing this stuff while it is still covered under our warrantee.
Old Nov 11, 2010 | 02:23 PM
silver01cltypes's Avatar
my armrest on my drivers door creaks sometimes when i lean on it.seems like its part of the door panel and the panel moves some when i lean on the armrest.anyone else get a creak from the arm rest?vinnier6 are talking about the top of the door panel right at window height?
Old Nov 11, 2010 | 03:23 PM
vinnier6's Avatar
same here, i dont usually drive with the stereo off...even when i am on the cell, i have the stereo on in the background...
vinnier6's Avatar
that is the part i am talking about, right at the top of the door panel...
Old Nov 11, 2010 | 07:34 PM
ashecnc's Avatar
Mine does that too, I wish mine could be tightened up, I put my elbow/arm up there all the time!
Old Nov 11, 2010 | 08:07 PM
vinnier6's Avatar
yep, my drivers side does it and my passenger side doesnt...i assume if you take off the door panel you can pad it up behind there, but thats why i am asking the question, otherwise i will just have to get busy on it some day and find out for myself...
Old Dec 21, 2010 | 01:46 PM
Umalum1990's Avatar
It is happening from always resting your arm.. After having there, repeatedly, all the time in the same area, it is probably getting worn, just like a creaky step on a staircase! Same thing happened to me on my TL and when I used to own my 2006 Lexus GS.
Old Dec 21, 2010 | 09:24 PM
vinnier6's Avatar
thats not whats happening, mine is the whole piece that creaks when you touch it, and its been like that since day one...
Old Jul 17, 2011 | 09:52 PM
ashecnc's Avatar
Did you fix this, mine is getting worse!
Old Jan 10, 2013 | 02:36 PM
adam38's Avatar
I noticed the same issue on mine after buying it in July. One of those little things that for a car in this price range I find a little unacceptable. You can make it creak by pushing on the door panel toward the top. I tried a couple of other 4G TL's and they do the same. I have no reason to take the panel off yet, but if I ever do, I'll be looking into a fix. It's minor but annoying.
Old Jun 11, 2013 | 03:48 PM
iamdk72986's Avatar
hey i know this is an old thread but i'm having the same problem on the driver's side only. anyone fix this yet?
Old Sep 10, 2013 | 06:24 AM
dethred's Avatar
I just happened upon this thread. After fighting with the dealership a couple years ago, they finally resolved the problem by apparently putting some sort of fabric or foam between the door panel and the door itself. No creaking since then, and it makes the car feel a bit better.
Old Sep 12, 2013 | 07:57 PM
JM2010 SH-AWD's Avatar
For you owners with "creaks" or "rattles" in the doors try buying some Shin-Etsu grease at the Honda or Acura dealer. My '10 was starting to get some of these, mostly in hotter weather, and it was getting to the point of annoying.
I bought a tube of the magic stuff (don't even want to know what's in it - use rubber gloves) and after cleaning all the door weatherstripping and the adjacent body panels it contacted with the door closed, I applied a very thin layer of Shin-Etsu to all the weather stripping on all 4 doors.
Result: it's been abnormally hot here all week - prime rattle weather - and I've heard nary a peep, even on rough streets with the audio turned way down. It may even have made the car a tick quieter on the highway too. Now my car sounds nice and vault-like again, just as it did when it was new.
Try the stuff. I think you'll be amazed.
Old Sep 13, 2013 | 01:26 PM
jim_c's Avatar
There are videos in some other threads in the audio section on here, and also on youtube, about how to remove door panels.
Jul 16, 2017 07:33 AM
chasingthecool
Mar 9, 2017 05:16 PM
soupi
14
Nov 15, 2015 11:15 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
