After timing belt service odd engine noise
Old Nov 7, 2025 | 10:14 AM
Ajain83's Avatar
5th Gear
I know there have been a lot of posts about this, but j. My case all the parts were replaced idling pully, and water pump, and have an odd noise. Should I be taking it to a shop? https://youtube.com/shorts/44yzmiwnrvs?si=Ob54ZHrC2Xdi2yrg
Old Nov 8, 2025 | 04:13 PM
csmeance's Avatar
could be a bad tensioner or kit, where did you get it from? Did they do a valve adjustment also?
Old Nov 8, 2025 | 04:29 PM
Ajain83's Avatar
5th Gear
Dont know if they did a valve adjustment (will check on that) got the kit from Amazon, replaced all pulleys, and crank pulley seal. https://a.co/d/74DJj0X appreciate your help with this...
Old Nov 8, 2025 | 06:28 PM
altair47's Avatar
The kit is clearly garbage, and it's the last thing I'd skimp on with a motor costing several thousand. What's the noise you tolking about: that awful knocking or the belt tensioner growling? Was that knocking there before the timing belt was replaced?
This is exactly what happens with the belts in kits like these.
But in this case, the guy was lucky. Usually, he just falls apart without any symptoms.
Old Nov 8, 2025 | 07:25 PM
Ajain83's Avatar
5th Gear
ther was no noise before the belt and water pump was replaced. Which kit would you suggest, think will have to redo this job. Thanks
Old Nov 8, 2025 | 07:45 PM
altair47's Avatar
I still don't understand what kind of noise exactly bothers you?
https://www.rockauto.com/en/parts/ai...onent+kit,5759
Old Nov 8, 2025 | 08:09 PM
Ajain83's Avatar
5th Gear
its the tick tick noise, sounds like something is loose. I can hear it inside the car when under 1000rpm or idling. And you might be spot on with the tensioner. Will open it up and share what I find. Thanks.
Old Nov 8, 2025 | 08:13 PM
altair47's Avatar
Well, if this knocking was not there, then you need to quickly replace this kit and it is advisable not to start the engine on it.
Old Nov 13, 2025 | 09:49 AM
Ajain83's Avatar
5th Gear
Took it to a shop and they are not concerned with the noise, regardless, I will go ahead and change the parts out with the kit you mentioned, as its just a matter of time before it fails. Thanks
Old Nov 13, 2025 | 10:56 AM
Very wise
Old Nov 17, 2025 | 03:19 AM
RayNA's Avatar
What do you think about kits made by GATES, are they any good? I changed the timing belt myself from one of those kits, 3 years ago, and so far so good. Knock on wood...lol
Kenrh1
May 31, 2020 08:08 PM
Lbeyy
Apr 17, 2020 07:41 AM
cls2002
2G CL Problems & Fixes
Oct 16, 2013 09:47 PM
Tvdie23
Nov 4, 2012 05:09 PM
tolea
Oct 23, 2008 01:14 AM
