Pcd - cel?
Old Jan 19, 2017 | 04:18 PM
stevesin's Avatar
Pcd - cel?
Can't find anything recent, but do the new PCD's from RV6 throw a CEL?
if so, what can be done to get rid of it
Old Jan 20, 2017 | 06:40 PM
KarKraze's Avatar
Not sure about the new PCD's . Some people have successfully removed CEL by playing around with the spacing of the O2 sensors. If all else fails, you can purchase the K Tuner which will disable the CEL.
Best bet is to contact Richie @ RV6 and run the same question by him.
Old Jan 24, 2017 | 10:44 AM
herbert6368's Avatar
No CEL for my pcd and jpipe
Old Feb 1, 2017 | 04:28 PM
ExcelerateRep's Avatar
Former Sponsor
If properly installed there should be no CEL.
The pre-cat deletes come with defoulers to space out the o2 sensor, if it throws a CEL you can try adjusting those by turning them in or out
And, if all else fails (which it shouldn't) you can always K-tuner it out!
We have the RV6 PCD's in stock, ready to ship here: RV6-PCD-TL-4G - RV6 Pre Cat Delete - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Good luck!
Old Feb 2, 2017 | 09:18 AM
stevesin's Avatar
thanks for the responses, just had them installed. only thing irking me is the gas smell, but i'm hoping it eventually goes away.
and I will be getting ktuner, just seeing if i can go the used route before i go the brand new route
Old Feb 2, 2017 | 05:36 PM
KarKraze's Avatar
It won't go away. Nothing wrong with a used K Tuner, just make sure it's unlocked from the seller ECU.
Old Feb 2, 2017 | 06:06 PM
KarKraze's Avatar
Forgot to mention, if you decide to add a J Pipe at a later date the rasp will be real.
Old Feb 3, 2017 | 09:27 AM
stevesin's Avatar
keeping the stock jpipe for the time being.
just sucks that nobody local sells ktuner, i've tried 4-5 places. might have to bite the bullet and get it online
Old Feb 4, 2017 | 09:47 PM
carbonTSEX's Avatar
The Original Shawdy
I have PCD and no check engine light. I did but it was due to the defouler being loose.
I have PCDs, Jpipe and full exhaust and there is a lot of back pressure but it puts down good power and it's loud. Also have it custom tuned. If you want to avoid the rasp, get high flow precats (HFPC).
Old Feb 5, 2017 | 09:12 AM
stevesin's Avatar
It's definitely loud. Next step is getting it tuned, and mayyyybe hfpc. Canadian dollar sucks right now, so need to slow down. So far no cel, the shop I went to did a great job installing
Old Feb 5, 2017 | 01:03 PM
KarKraze's Avatar
^^ Which shop did you go to ?
Old Feb 5, 2017 | 03:57 PM
KarKraze's Avatar
Maybe you made a mistake in your post. You already installed the PCD correct ? if so then you don't need the HFPC. Perhaps you mean you want to install a J Pipe ?
Old Feb 5, 2017 | 04:41 PM
stevesin's Avatar
You're right I did 🙃
I went with noyzboyz in Scarborough. Came highly recommended from cruzan
Old Feb 6, 2017 | 09:54 PM
Blaze9's Avatar
Both J-Pipe along with PCD or just the j-pipe alone?
Old Feb 6, 2017 | 10:11 PM
carbonTSEX's Avatar
The Original Shawdy
That's in reference to PCD with an aftermarket Jpipe.
Curious how that combo sounds with stock exhaust.
Old Feb 7, 2017 | 05:20 AM
KarKraze's Avatar
"CarbonTSEX" gave you the correct answer. The J Pipe with third cat delete as a stand alone mod will give you any rasp and will enhance the tone slightly.
With the reference to time to install mentioned in another thread. The Removal of the Second Cat is difficult due to limited space. It is time consuming and if you are going with HFPC the re installation is just as time consuming. If replacing with PCD then the install is simpler but it is still difficult to remove the Stock Cats.
I stayed away from the PCD' s mainly because of the rasp and gas smell. Love the HFPC and J Pipe combo though.
Old Feb 7, 2017 | 06:01 AM
KarKraze's Avatar
^^^ Typo mistake, the JPipe with third Cat delete will not produce any rasp.
Old Feb 7, 2017 | 03:46 PM
carbonTSEX's Avatar
The Original Shawdy
Whats the difference in gains? Slightly more for PCD since it's just a straight pipe but how much more?
Old Feb 7, 2017 | 06:40 PM
KarKraze's Avatar
From hearsay.......... slightly more ( 3 HP ) with the PCD.
Old Feb 9, 2017 | 09:09 AM
Former Sponsor
Hey, when you're ready to get it we have you covered!
You can see it online here: KTunerFLEU - Flash Based Hardware - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Don't forget to check us out for your performance needs; PM me for quotes and with questions!
Old Feb 9, 2017 | 05:03 PM
stevesin's Avatar
Pcd finally threw a cel after a week. Think defoulers came loose?
Old Feb 9, 2017 | 07:25 PM
KarKraze's Avatar
Couple of questions...... did you purchase the PCD new from RV6 ? Did you get spacers with it ? Did you scan to see what code you triggered ?
Not sure if the defoulers came loose but many times the CEL will not come on immediately, they will come on after the ECU senses a particular parameter is constantly registering over X number of kms . Also far as i know certain driving style will trigger the CEL, gearing down from high RPM and pulling to red line.
I know my car was running rich with the Mods but without the tune. After the tune I am getting a near perfect air / fuel mix.
Old Feb 9, 2017 | 07:39 PM
KarKraze's Avatar
For an Accord but just posting for info
Old Feb 9, 2017 | 10:35 PM
carbonTSEX's Avatar
The Original Shawdy
We cant really give you advice on how to correct the code unless you get it scanned. From there we may be able to steer you in the right direction. In my case, you could move the defoulers with your hand so it was easy to tell. Not sure how they came loose but it was an easy fix.
Old Feb 10, 2017 | 08:01 AM
stevesin's Avatar
ok, gonna go get it scanned, will report back.
Old Feb 11, 2017 | 03:35 AM
CruzanTLSH-AWD's Avatar
I as well love the HFPC/J-Pipe combo as well. I also have the Ktuner but running on base map... I'm sure car running rich even with the base map because every now and then you can smell it especially when gearing down or coming to a stop from flooring it. Love my set up tho but ain't had much time to enjoy it since I did it right near winter started. My reason for HFPC just simple... ain't want that gas smell with the lil princess in the car. And "supposedly" have more low end TQ.
Old Feb 11, 2017 | 03:45 AM
One guy in here actually did it and ended up installing his stock J-pipe and I bought the aftermarket one from him... He said the exhaust was deeper and more growl to it but prefer the PCD'S with the stock setup.
Old Feb 11, 2017 | 07:58 AM
stevesin's Avatar
Light went away. Cruz was right. Was freezing out the other day, warmed up and light went awat
Old Feb 11, 2017 | 09:19 AM
carbonTSEX's Avatar
The Original Shawdy
Yeah I remember reading his review.
Mine just smokes more than it stinks. Wife says she can't tell and doesn't mind it.
Old Feb 11, 2017 | 09:20 AM
carbonTSEX's Avatar
The Original Shawdy
Sorry I never learned how to use the multi-response, but Stevesin, glad to hear the light went away.
Old Feb 11, 2017 | 11:40 AM
KarKraze's Avatar
Good stuff.
