Replacing front speakers and tweets
Old Jan 27, 2011 | 03:27 AM
mreno577's Avatar
Question Replacing front speakers and tweets
I recently picked-up a 2009 TL SH-AWD and much to my dismay the front right speaker is blown. After reading a little it seems to be a fairly common problem with the TL, which is why I decided not to have acura put the same speakers back in it.
I purchased a set of POLK components and plan on putting them in this weekend. Anyone have any tips, tricks, or warnings when removing the door panels and A-pillars or are they pretty straight forward.
Old Jan 27, 2011 | 07:12 AM
Brew0360's Avatar
All of the info you need can be found by doing a thread search. Good Luck.
Old Feb 24, 2011 | 06:27 PM
jaru0462's Avatar
Why replace when you still have a warranty
I would have waited until my warranty ran out or make them change to a more reliable brand of speakers. Its not your fault that the speakers are crap.
Old Feb 25, 2011 | 12:01 AM
potmilkz's Avatar
bring it to acura, tell them to change it.. its probably not going to happen again.
just my 2cents
Old Feb 25, 2011 | 02:52 AM
Stew4HD's Avatar
The OP hasn't respended to this thread in a while .. err, at all
Old Mar 22, 2011 | 03:47 PM
Loli's Avatar
I have been searching this board and have not seen anything that shows/ tells how to remove door panels or access the tweeters on a 4G TL.
What am I doing wrong?
MGG
Old Mar 22, 2011 | 05:48 PM
Mr Marco's Avatar
I could only locate 3G replacement thread as well. No one has step by step on this?
Eno577 you could be our replacement guru.
Old Mar 22, 2011 | 09:08 PM
Stew4HD's Avatar
Brew0360 replaced his speakers..well, upgraded them
Old Mar 23, 2011 | 02:33 PM
jnc2000's Avatar
search for removing door panel
https://acurazine.com/forums/4g-tl-2009-2014-123/4g-diy-removing-door-panels-811516/
Old Mar 28, 2011 | 01:11 PM
Loli's Avatar
Yes I was searching for speaker replacement and front door speaker and tweeter replacement.
I found pictures and details of both by searching for door panel removal and front A Pillar removal in 4G.
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
08 NBP TL
Sep 8, 2015 08:49 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
asahrts
Sep 4, 2015 05:55 PM
