iPhone bluetooth + iPod function
Old Jan 4, 2012 | 02:07 PM
mightl's Avatar
Can I use it as iPod and still connect to bluetooth (Hands Free) for voice call?
I had both connected (bluetooth & USB), but then iPod no longer output music through the system... (I'm not on the phone).
Anyone?
Old Jan 4, 2012 | 03:19 PM
dwest1023's Avatar
I have a iphone 4g and Ican play my ipod and use the bluetooth as well. If the music is playing through the usb it will pause when calls come through. I not sure why you are having a problem. Just make SURE when you enter the car the bluetooth connects to the car first. THEN connect the usb. Otherwise you will only get sound from the ipod in bluetooth mode. If you do not get any sound from the ipod, you can manually go your ipod and switch the audio to usb. I hope this is clear?
Old Jan 4, 2012 | 07:14 PM
mightl's Avatar
I have the connection sequence reversed, I guess that's the problem... but I also tried the bluetooth audio stream when USB iPod is not outputing, still nothing coming out of it either.
Anyway, I'll reverse the connecting sequence and see how it behaves. Thanks!
Old Jan 5, 2012 | 08:36 AM
tuxacura's Avatar
Anyone?
I have something similar happened to me today. I didn't hear any sound from my iPhone but I can see all the tracks, etc in the Audio menu. I looked at my phone in the Music app and it says accessory connected (car's control) but below there is a docking icon. If you selected and choose USB over Handsfreelink it should play.
Hope that helps.
Old Jan 5, 2012 | 11:18 AM
Pseudomaniac's Avatar
If you use the USB/ipod cable to connect/charge, AND you've got it set up with bluetooth audio, it fight initially over the audio if you've plugged it in as soon as you start the car. Once bluetooth hooks up, it will take over as the audio source on the iphone, and if you're in ipod/usb mode on the stereo, will lose sound, unless you flip the audiosource to handsfreelink on the car, or flip it on the phone back to the dock connector.
Old Jan 24, 2012 | 08:13 PM
mightl's Avatar
exactly like dwest or pseudo had said. thanks.
Old May 4, 2012 | 06:40 AM
txhogfan94's Avatar
7th Gear
Thank you guys and gals for clearing this up. Just took delivery on my 2012 TL Advance and this problem was driving me crazy!
4drviper
Apr 23, 2025 07:13 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
soupi
14
Nov 15, 2015 11:15 AM
SUPRMN84
Oct 7, 2015 09:46 PM
TLguy42
Sep 26, 2015 11:27 AM
