HDD Ripping CDs
Old Nov 24, 2010 | 06:55 PM
shabadoo25's Avatar
HDD Ripping CDs
How long does it take to do a whole cd? Also, if I put in a cd and then switch to XM mode, will it finish off ripping the cd?
Old Nov 24, 2010 | 07:18 PM
JM2010 SH-AWD's Avatar
CDs rip in about 1/3 to 1/4 of the playing time or so.
Your second question is a good one. Don't know the answer.
Old Nov 24, 2010 | 08:28 PM
crxb's Avatar
believe it continues
Old Nov 24, 2010 | 08:41 PM
caps59's Avatar
it does continue to rip when in another mode (radio, etc). the only time it doesn't rip is when the ignition is turned off. ripping resumes when the ignitinn is turned on.
best, caps59 2010 tl shawd ccb/umber
Old Dec 1, 2010 | 03:25 PM
LloydAbrams's Avatar
I just bought a TL with the Tech package and tried to upload a CD and was not succesful. Although not explicitly stated, do I have to have the engine running in order for a CD to be ripped to the Hard Drive?
Old Nov 6, 2012 | 10:27 AM
avikban's Avatar
even if you change to xm/ Radio/ usb, it will still continue ripping but system should be on (running / accessory mode)
Old Nov 6, 2012 | 11:38 AM
CerberusKy's Avatar
Nope. will rip when in accessory mode.
I have found that if you turn the car off while ripping a cd, I have had an occasional issue with the cd ripping properly. Most of the time it worked fine though.
Old Nov 11, 2012 | 05:30 AM
dcrandon's Avatar
What format does it rip to? MP3? If so, what bit rate?
Old Dec 5, 2012 | 11:12 AM
avikban's Avatar
I found in some other posts it's mp3 @128 only
xsilverhawkx
Sep 28, 2015 06:51 PM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
