Auto Interior Illumination
Old May 2, 2010 | 02:06 AM
t5620's Avatar
what does it does?... in the keyless setting Meter
I don't get it, I don't see any difference whatsoever between max min, hi, low, or off.
Acura TL 2010 no navi
Old May 2, 2010 | 12:07 PM
SSGHutch's Avatar
The auto interior illumination refers to the soft blue led's that are near your map lights. They look like two small holes. When's it's dark out, you'll notice that your cup holders and front foot wells are slightly illuminated. There is a slight difference between low, med, and high.
Old May 3, 2010 | 08:58 AM
Pete2010's Avatar
You can set the amount of the int illumination? I'll have to try that out, totally missed that.
Old May 3, 2010 | 03:21 PM
SSGHutch's Avatar
That's the fun with this vehicle, so much tech that it's hard to find it all lol.
Old May 3, 2010 | 03:45 PM
Eli's Avatar
Eli
Pretty sure the blue ambient lights, and all the gauge/button lighting are controlled all at once by the dimmer control buttons.
The auto interior illumination setting refers to how sensitive the automatic dash lighting is to outdoor conditions. It's separate from the auto headlights. So when it starts getting darker out, the setting controls how dark it has to be outside to turn on dash lighting.
Old May 3, 2010 | 06:20 PM
SSGHutch's Avatar
See? Now I have learned something new lol!
Old May 3, 2010 | 06:25 PM
t5620's Avatar
Yes, That is correct, Thanks for the information, I could not figure it out.
have a nice day.
Old Jul 7, 2019 | 10:48 PM
AliShibaz's Avatar
Now I need to find out what the dimmer control buttons are ?
Old Jul 8, 2019 | 01:21 PM
echodigital's Avatar
From TL to RDX
For the front driver & passenger foot wells, you need drill out hole or change the LED module. They used a BLACK opaque module and you can't see the light at all.
https://acurazine.com/forums/fourth-...-light-947730/
Old Jul 10, 2019 | 01:41 PM
SoFla David's Avatar
From the Manual:
While the headlight switch is turned on, the interior lights gradually dim, as the outside light level gets low. You can customize at which outside light level the lights start to dim.
There are MAX, HIGH, MID, LOW and MIN levels and OFF for the auto interior illumination settings.
If you want the illuminations to start dimming as early as possible, select MAX. For illuminations to start dimming as late as possible, select MIN. Choose HIGH, MID, or LOW for levels in between.
To disable the auto interior illumination function, select OFF.
Old Jul 10, 2019 | 06:06 PM
AliShibaz's Avatar
Hello David and thank you.
I must say that I read the description you quoted from the manual and I couldn't make any sense out of it. This feature seems like a rather minor one to me and so I'm not complaining. As a matter of fact, I have never before owned a car with even a tiny fraction of the controls this car has. Part of the reason I find things so confusing is that there are two different controls for Interior Illumination.
One control is in the METER SETUP section called AUTO INTERIOR ILLUMINATION. The second control is in the LIGHTING SETUP section and it's called INTERIOR LIGHT DIMMING TIME.
In echodigital's post, he or she talks about some light that are down by your feet. I had always thought that INTERIOR ILLUMINATION referred to the map lights positioned near the rear view mirror and the light at the top of the cabin in the back seat. I have tried to fiddle with both these controls to see if I could understand how they work but I just don't get it.
One problem I have is trying to figure out what the "outside light level" could possibly have to do with the interior lights. The manual says:
AUTO INTERIOR ILLUMINATION: While the headlight switch is turned on, the interior lights gradually dim, as the outside light level gets low. You can customize at which outside light level the lights start to dim.
My first thought was "outside light level" refers to how light or dark it is outside. My understanding was that as it gets darker outside, you can control something about the rate at which the interior lights dim. But why would you want to dim the interior lights as it grows darker outside? I would have thought that as it grows darker outside, you would need more interior lighting - not less. Moreover, what does this have to do with the headlight switch being on or off? I don't understand any relation between the headlights and the way the interior lights dim as it gets lighter or darker outside.
I found it impossible to experiment with this feature to try and figure it out because I cannot control how light or dark it is outside. I must admit this feature completely mystifies me. If anyone can explain what this is about, I would appreciate it.
Echodigital seems to suggest there are some soft blue lights near your feet that might help to see down there if you drop something. But apparently, those lights are somehow covered with something and I would have to drill some holes in order to see them. I would be too afraid to be drilling any holes in the driver's compartment. I would be afraid that I might damage something or drill into a fuel line. I'd love to understand how all the SETUP options work. But I wouldn't want to understand them at the risk of damaging my MDX.
Old Jul 10, 2019 | 07:25 PM
During the day, the illumination of instrument cluster is at MAX brightness so that you can read it in the bright daylight. At night, when the headlights come on (either by manually turning on the headlight switch, or when the light sensor doesn't see daylight if the headlight switch is set to auto), the cluster dims down so that the bright lights of the gauges don't blind you in the dark. At the same time, many buttons on the dashboard, doors, steering wheel, center console, and overhead console also turn on when the headlights come on. While the headlights are turned on, you can adjust just how much the instrument cluster dims and how bright all these buttons glow by using the up and down buttons located on the dash just to the left of the steering wheel. You can even raise it up all the way and put it on "MAX brightness" which overrides that night dimming functionality and lights everything up as bright as it will go, including lighting the instrument cluster as bright as it is during the day (way too bright for at night).
The METER SETUP section called AUTO INTERIOR ILLUMINATION controls how that transition of the instrument cluster between bright (day) and dimmed (night) happens. Is it sudden, like flipping a switch, or does it fade between bright and dim either quickly, or slowly (easier for the eyes to adjust). This setting has nothing to do with the dome lights, blue under dash lights, or any other lights.
The LIGHTING SETUP section setting for INTERIOR LIGHT DIMMING TIME is strictly for the dome lights. That is the one that controls the dimming behavior of the dome lights (map lights) after you close the last door. There is no correlation between outside light level and dome light behavior.
The outside light sensor that triggers the automatic switching for headlights, instrument cluster lights, and other functions is the square translucent sensor on the top of the dashboard right behind the hump for the entertainment system screen. You can trigger the sensor at any time by either covering it (during the day) to make it think it got dark outside, or by shining a flashlight at it at night (to make it think it turned into daytime).
The blue lights under the dash have a very dark plastic cover that lets very little light through. Most people don't even realize that they are there due to the tiny bit of light that gets through the dark cover. Many of us modify them by removing the light from under the dash (Just twists off), snapping off the cover, and drilling a hole in the dark lens so that more light can pass through. The drilling is done on a workbench, not in the car.
Hope that helps.
Old Jul 11, 2019 | 12:38 AM
AliShibaz's Avatar
Hope that helps.
Hope that helps?
Wow! That is just about the best explanation of anything I could not understand. I cannot thank you enough for that detailed explanation. I would never have guessed that "interior illumination" referred to the brightness of the instrument cluster. But of course that makes sense. I thought there was a way for people to rate posts that helped them. But all I could see is a "LIKE" button.
But I just want you to know that I really appreciate your taking the time to provide me with such an excellent explanation. I would have never figured that out on my own.
P.S. I also want you to know that I really love my Acura. I have owned several other cars but never have I owned one that ran as smoothly and the ride was as comfortable and they provided so many options for me to control so many behaviors of the car. It's truly a fabulous vehicle!
Old Jul 12, 2019 | 12:19 PM
From TL to RDX
This post has some nice pictures of the drilled out holes:
https://acurazine.com/forums/fourth-...ighter-783070/
I used a "counter sink drill bit" to make my hole. It's the best bang for the bug mod ever for 4G TLs.
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Jimmy_D
Oct 7, 2015 11:52 PM
malvothegreat
Sep 29, 2015 12:38 AM
