Foot Well Light...
Foot Well Light...
I am going to try this now and the images are gone from this post.
https://acurazine.com/forums/fourth-...ighter-783070/
The drivers side seems easy - it's like taking out the panel to replace a fuse. There is a little 'handle' you can twist to release the it.
The passenger side doesn't have the same handle but has a deep handle in the back. How hard can you pull it? How do you remove the passegner panel easily without breaking it.
I am just going to drill a hole in front of the light in it to see if the wheel wells light up more at night time.
THANKS!
THANKS!
Thanks justnspace - I found these images. It seems like he took good ones of driver side but not of the passenger side. I can will attempt to pull it carefully.
tl led under dash lights by HAWAII-TSX | AcuraZine.com
TheMuffinMan, thanks for all the part numbers and pics! So if I want the blue led's with clear lens, I can either buy 34760-TL0-J11 from the TSX Wagon (blue LED light w/ CLEAR lens) OR 34760-TL0-G11 - Amber Light (clear lens) - 2011-2013 Acura TSX and swap the lenses around correct?
34760-TL0-G11 (Amber/Clear) OR 34760-TL0-J11 (Blue/Clear)
Are the part numbers to purchase
WOW - I just installed the clear lens and it's pretty cool. It makes a HUGE difference. I decided to counter sink drill a 'smaller' hole on the driver side lens (stock black) and used the clear "plastic" container to cut a smaller circle as a home made "lens cover" over it. I was hoping to make the driver side well a little less bright. This is a very easy mod!
TSX clear is clear so no drilling is required. I drilled the driver side and used the TSX on the passenger side. I put a clear plastic cover (anything clear/plastic/thin that can be cut with scissors) on the drivers side.
usdmJON
ILX Performance Parts & Modifications
15
Sep 8, 2016 12:04 PM
lanterna_viridis
Apr 18, 2016 02:31 PM
Rowdy
Mar 19, 2016 08:17 PM
