Reverse mirrors
Old Dec 20, 2014 | 04:22 AM
kdaddy's Avatar
3rd Gear
Question Reverse mirrors
When i first bought my tl ...when i put it in reverse both mirrors would tilt down. ...the other day i went to adjust the mirrors ......now when i put the car in reverse once its position on L just the left mirror tilts...when its on R just the right mirror tilts....when the nob is positioned in the middle no mirror tilts.....Did i broke it? ....how can i fix this so both mirror tilts at the same time....HELP!....
Old Dec 20, 2014 | 08:20 AM
echodigital's Avatar
From TL to RDX
On my 2009 TL, it only lowers 1 mirror when in reverse.
Old Dec 20, 2014 | 08:27 AM
Cooldude01's Avatar
I have a 2012 SH-Awd and it's the same thing. I don't believe both mirrors will tilt when you're backing up. You can only select either left or right.
The same question was asked on 3rd Gen and it's only one mirror.
https://acurazine.com/forums/second-...ersing-814248/
Old Dec 20, 2014 | 08:52 PM
Edward'TLS's Avatar
6G TLX-S
Only 1 side mirror (either left or right) will be tilted down when the transmission is put into reverse, provided that the mirror switch is not in the center position.
Old Dec 22, 2014 | 12:37 PM
kdaddy's Avatar
3rd Gear
Thanks....thought i broke it.....
Old Dec 22, 2014 | 01:04 PM
Old Dec 22, 2014 | 02:16 PM
potmilkz's Avatar
your trippin lol.. it was designed for 1 to turn down when put in reverse..
Old Dec 23, 2014 | 04:13 AM
kdaddy's Avatar
3rd Gear
My cousin have a 05 TL amd both of hers move. ...
Old Dec 23, 2014 | 09:46 AM
def. not at the same time.
I can confirm the third gen TL's only having one mirror point down in reverse.
Old Dec 23, 2014 | 03:09 PM
sockpuppet's Avatar
This feature is described in the manual; there's really no need for any discussion on whether it's working properly. In 4G, only one mirror will tilt on reverse, and then only when the switch is set to the corresponding side.
OP, if you had both mirrors tilting, and now only one does, then congratulations; your car was broken, but now it's fixed.
On another note, IMHO, it would be a rare set of circumstances where having both tilt is a benefit. On a bigger vehicle, like an SUV, I could see the benefit, but not on our little whips.
ITSJESTER
17
Dec 6, 2018 02:29 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
STC
Sep 23, 2015 04:36 PM
