D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
Old 05-05-2014, 04:05 PM
  #2641
robocam's Avatar
Welcome! 20s will fit fine because they make 235/30R20 sized tires, which give you the same overall diameter as stock (could use 245/30R20 too among many other possible sizes depending on your wheel width). You could probably fit 245/30R21 on 21" wheels too. That's 1.2" bigger than stock, which should fit with no problems, but I wouldn't do that. Putting larger tires on defeats the purpose of getting a larger wheel (the bigger tire makes the wheel look smaller). I recommend using Google to search through the Acurazine site to see what people have done. Also browse the tire & wheel threads.
But I agree with ebelp that it will look silly without being lowered. I just got 18s with 235/40R18s (stock diameter), and I think my TL now looks like a 4x4. I'm going to lower it a couple inches or so.
Can you show us what kind of look you're trying to achieve?
Here's a 4th gen on 22s. That's probably what the 3rd gen would look like with 21s.
That pic is from this thread.
https://acurazine.com/forums/4g-tl-tires-wheels-suspension-298/22s-2013-tech-891059/
Originally Posted by jayd0002
Hi all. Im new to this forum and a new TL owner. I just bought a 2004 TL with 47,000 miles.
Can anyone tell me what the biggest rim size I can get away with- without having to make any suspension modifications, or having to do anything crazy?
any help would be greatly appreciated!!
Old 05-09-2014, 01:20 AM
  #2642
8th Gear
ocdclean's Avatar
Wheel Make/Model:Avid.1 av-20
Wheel Size (18x8.5):
Wheel Offset (+33):
If lowered (amount):Stock currently - future minor drop
Questions on Tires
Width/Sidewall-Diameter (235/40-18)???
http://www.nlmotoring.com/AVID-1-AV-...h%20wheels=614
I'm leaning towards 8.5 wide and +33, but would 9.5 work with +22? I know at stock height I wouldn't really have any problems with anything, but what about lowering about 1.5" here in the near future? My fenders aren't rolled.
Old 05-09-2014, 03:54 PM
  #2643
nostra's Avatar
[B]Questions on Wheels
Wheel Make/Model: Katana K150
Wheel Size (**X**): 17x8
Wheel Offset (+**):35et
If lowered (amount):A-Spec Suspension
Old 05-13-2014, 10:49 PM
  #2644
4th Gear
elcatrachito18's Avatar
05 acura tl 6speed with navi.
Wheel make: oem wheels from a 06 acura rsx type s
Wheel size: 17x7
Wheel off set: 45mm offset
If lowered 1.5 inches with teins.
What size of spacers do I need to have clearance in the brembo calipers?
__________________
Old 05-14-2014, 09:10 PM
  #2645
04' tl 6 spd
Joey tl's Avatar
04 acura tl 6speed.
Wheel make: VOLK CE28N
Wheel size: 18.8.5 F/18X9.5 R
Wheel off set: 30mm offset F/ 34MM OFFSET R
Tires are 235/40/18 F / 255/35/18 R
Would they fit? would the front spec clear the brembo calipers without spacers? would I need fender work?
Old 05-16-2014, 11:36 PM
  #2646
ReKLeS's Avatar
Vossen cvt
Questions on brembo clearance
Auto
2008 type s
Wheel Make/Model: Vossen CVT
Wheel Size (**X**): 19x8.5
Wheel Offset (+**): +32
If lowered (amount): stock non aspec
Will these fit without any mods?
Old 05-18-2014, 05:35 PM
  #2647
Level: Noob
Mrtastygoody's Avatar
Questions on Wheels
Wheel Make/Model: Enkei RPF1
Wheel Size: 17x9
Wheel Offset: +45
If lowered: On manual a-spec suspension with an 04 Base Auto
Questions on Tires
Tire Make/Model: BF Goodrich G-force Sport COMP-2
Width/Sidewall-Diameter: 255/45/R17
Already have the tires, looking at the wheels. I'm on 17x8.25 +30 XXR 530's right now and they are rubbing with these tires. Would switching to the Enkei's alleviate my problems, even though they're 9 wide?
Old 05-19-2014, 07:07 PM
  #2648
8th Gear
Ackurah's Avatar
Wheel Make/Model: JNC 005
Wheel Size (**X**): 18x9
Wheel Offset (+**): +15
If lowered (amount): 2in Looking to stretch 205s /40 /18
Old 05-19-2014, 09:13 PM
  #2649
yoks032rs's Avatar
I think you're going to have to go with 215's the 205's may not stay on
the lip.
Old 05-21-2014, 12:35 AM
  #2650
iHeartmyHonda's Avatar
Questions on Wheels
Wheel Make/Model: STR/JNC 019
Wheel Size: 18x9
Wheel Offset: +27
If lowered (amount): None ... installing with Koni yellow and Tein springs
Old 05-21-2014, 08:07 PM
  #2651
Rev High; Drive Happy
o4Komodo's Avatar
Originally Posted by iHeartmyHonda
Questions on Wheels
Wheel Size: 18x9
Wheel Offset: +27
what the question?
what tires are you running and do you have brembos up front?
Old 05-22-2014, 11:13 PM
  #2652
#TeamBoosted
TSXinity's Avatar
2007 Base TL+Navi
Questions on Wheels
Wheel Make/Model: Stance SC5 Machined Black/chrome lip
Wheel Size: 20x9 Front and 20x10.5 Rear
Wheel Offset: +32mm Front and 45mm Rear
If lowered (amount): H&R Sport on Tokico Blues so about 1.5 inch?
Before I order these rims, I already have tires on hand. Using 245/30/20 BF G-Force KDW all around. So rears will be stretched but GForce tires runs wider than normal with beefy sidewalls. Will I sit flush all around or will the rims stick out alot? What about rubbing issues? I do not want to roll fenders. I Have -2 camber in the rear and -1 up front.
Will this be ok?
They also have 20x8.5 +35mm and 20x10 +35mm as options. But I like the most concave possible.
Old 05-25-2014, 04:25 PM
  #2653
garrettdigital's Avatar
Originally Posted by garrettdigital
Looking at some wheels that offer 2 offsets that are supposed to fit. Which one is preferred?
Question on Brembo/Big Brake Clearance
Transmission: 6MT
Year/Trim: 08 Type-S
Wheel Make/Model: Drag DR-49
Wheel Size: 18x8
Wheel Offset: 35 or 45
If lowered (amount): ~1.5
Is the 45 offset the safer bet because I could always add a spacer?
Just to follow up, the 35 offset fits perfectly.
Old 05-30-2014, 11:17 AM
  #2654
2008 WDP Base TL
kev08wdp's Avatar
2008 base TL
Questions on Wheels
Wheel Make/Model: xxr 530
Wheel Size (**X**):18x8.75
Wheel Offset (+**):+20
If lowered (amount):1.5" max
I have been trying to find this on the xxr thread but I couldn't find the answer. I need daily drive capability and I'm trying to avoid fender pull/roll. Just so I'm clear, +20 gives the slight poke unless I slam the car right? I'm only going to lower about 1.5 inches at the most so would the +33 not be poking at all? If that's the case then I think I'll go with the +33 because I use my car to go all around 4 cities when I work and I don't want to destroy my fenders or chew up my tires. I plan on getting 225 tires if that helps at all
Old 05-30-2014, 09:09 PM
  #2655
Moved to the LOU
twigglius's Avatar
https://acurazine.com/forums/showthread.php?t=891059
I can only think of 1 TL that has ever looked with 21's. It was years ago, maybe like 2007. It was an AZine member in Japan and I think his screen name was Dancho. Look him up.
Old 06-01-2014, 07:27 AM
  #2656
#TeamBoosted
TSXinity's Avatar
Originally Posted by TSXinity
2007 Base TL+Navi
Questions on Wheels
Will this be ok?
Anyone?
Old 06-05-2014, 12:19 PM
  #2657
Andrew
VisualEchos's Avatar
Car: Standard 2007 TL
Wheel: 18 x 9.5 +40
Tire: 265/35/18
Suspension: Stock
I know the 265 works on an 8.5" +45 wheel from this thread...
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/they-said-couldnt-done-626278/
So I'm adding 1" in wheel width, and pushing the wheel outwards by 5mm. Do you think this will work with the stock suspension without rubbing on the inside? I know the 245/40 tire size will work for my 9.5" wheel, but I'm looking for BEEF, not stretch.
Thanks in advance for any info/advice.
Old 06-12-2014, 10:51 PM
  #2658
Starcraft II addict
Buda's Avatar
Wheel Make/Model: Volk SF Challenges
Wheel Size: 19 x 8.5
Wheel Offset: +42
If lowered (amount): 1.5 inch
Tires: Probably 245/35R19 might go 235s if have to but like the lip protection with the 245s.
Don't want to have to roll.
Old 06-14-2014, 08:09 PM
  #2659
Moved to the LOU
twigglius's Avatar
Wheel Offset: +42
Zero issues. Those will be sunk in pretty far... You could be lowered 3" with those specs.
Buda (06-15-2014)
Old 06-18-2014, 09:08 PM
  #2660
markp6mttl's Avatar
Wheel: 18 x 9.5 +40
Tire: 265/35/18
Suspension: Stock
https://acurazine.com/forums/showthread.php?t=626278
It depends, mainly on tire brand. You'll need to roll the rear fender for sure. I just did this same setup on my TL. Same size wheel. Had 235/40's, went to 265/35's. I'm lowered on Tein Street Flex coils (13" hub to fender gap), and it barely clears these, not sure if it would clear on stock suspension. I don't think this setup will work with any other wheel than a 18x9.5 +40. I think if it were a +38 it would rub the front fender, and a +45 probably wouldn't clear the control arm in front or the coilover on the rear. A +42 might, but it would be close.
VisualEchos (06-19-2014)
Old 06-19-2014, 09:36 AM
  #2661
Andrew
Thanks for the response man! The tires I bought were 255/40 because I wanted to be safe, but I can still send them back if I change my mind because they haven't been mounted. So, with stock suspension you think I'd need to roll the rear? Is this because there is no negative camber to tuck the tire a bit? And if that's true, I would need to do something to the front as well, as the front pokes 5mm more than the rear stock. Your thoughts?
Old 07-11-2014, 11:43 PM
  #2662
Road Racer / Solo Addict
EL BAN's Avatar
Finally getting rims for the ride.. 2008 Base TL
Questions on Wheels
Wheel Make/Model: Rota MXR-R
Wheel Size (**X**): 18x9.5
Wheel Offset (+**): +38
If lowered (amount): Eibach Pro Kit 1-1.5"
Will be using Dunlop Direzza's in 245/40/18.. Will be rolling fender in the back just in case (I do fender rolling)
Will this clear with the fender roll? Will I need to roll the front also?
I pulled a TSX front once but the guy was running 10" wide rims..
But I understand this setup would clear front and back.. Any feedback will be appreciated..
Old 07-15-2014, 06:28 PM
  #2663
ScoobyTL's Avatar
Transmission (Manual or Auto): Auto
Year/Trim (04-07, Base or Type S):Type S
Wheel Make/Model: Lancer EVO MR Enkei Wheels
If lowered (amount): Will be lowered by 1"
Will these wheels work on the TL-S? I couldn't find any pictures. I don't think I will have any rubbing issues if the tires are 235/45/17.
Old 07-15-2014, 06:53 PM
  #2664
CLtotheTL32's Avatar
Received 9,528 Likes on 6,183 Posts
Questions on Wheels
As long as you roll the rears you'll be fine.
I can't help with the Brembo clearance but you won't have any fender rubbing issues.
EL BAN (07-15-2014)
Old 07-15-2014, 07:05 PM
  #2665
ScoobyTL's Avatar
I was thinking that the Brembo clearance should be fine since the EVO has Brembos too? But if anyone knows for sure if they clear or not then that would be very helpful! I am trying to pickup a set across the country!
Old 07-15-2014, 08:17 PM
  #2666
EL BAN's Avatar
Thanks for the response, I rolled the rear last weekend.. If needed will roll the front also and roll the rear a bit more.. Glad I didnt sell the fender roller yet..
Ordered rims and tires today..
Old 07-27-2014, 10:39 AM
  #2667
EL BAN's Avatar
Cleared with no issues.. Running 245's but it should clear 255's also and might clear 265's.. Thanks for the responses..
Attachment 105647
Attachment 105648
Attachment 105649
Old 07-30-2014, 02:01 AM
  #2668
9th Gear
jjordan420's Avatar
2008 base TL
Questions on Wheels
Wheel Make/Model: vossen cv4
Wheel Size (**X**):20x9
Wheel Offset (+**):not sure of the offset
trying to figure out what size tires will be best without rubbing and dont wanna roll fenders thanks
Old 07-31-2014, 10:37 PM
  #2669
3rd Gear
RetroWerks's Avatar
2004 6mt
Questions on Wheels
Wheel Make/Model: Miro 398
Wheel Size (**X**):18x9.5
Wheel Offset (+**):+34
If lowered (amount):about 1.5" (neuspeed springs)
I know I have to run a 15mm spacer in the front to clear the brembos, my question is will the wheels stick out too much? And what tires would I have to run?
Old 07-31-2014, 10:58 PM
  #2670
story.customz's Avatar
Originally Posted by RetroWerks
2004 6mt
Questions on Wheels
https://acurazine.com/forums/3g-tl-photograph-gallery-96/shotta-nbp-progress-thread-update-897501/
check out shotta's thread
235/40/18
can't help with brembo fitment though sorry
RetroWerks (07-31-2014)
Old 07-31-2014, 11:03 PM
  #2671
3rd Gear
RetroWerks's Avatar
Originally Posted by story05
https://acurazine.com/forums/showthread.php?t=897501
235/40/18
Thanks, yeah I saw the wheels on his car before I bought them an they look perfect, but then I realized that he doesn't have brembos, so I'm just really worried about the wheels sticking out too much, I don't want mexiflush haha
Old 08-01-2014, 08:42 PM
  #2672
9th Gear
jjordan420's Avatar
[QUOTE=jjordan420;15100198]2008 base TL
Questions on Wheels
trying to figure out what size tires will be best without rubbing and dont wanna roll fenders not lowered but if i do
any help would be great thanks and the offset is 48
Old 08-02-2014, 08:54 AM
  #2673
[QUOTE=jjordan420;15104022]
Originally Posted by jjordan420
2008 base TL
Questions on Wheels
235/30/20
245/30/20
Old 08-02-2014, 04:48 PM
  #2674
5th Gear
Overlimit's Avatar
Questions on Wheels
Wheel Make/Model: Verde black saga
Wheel Size (**X**): 20 inches
Wheel Offset (+**): high (not sure how much)
Wheel width : 8.5
05 base tl
Questions on Tires
Tire Make/Model: ohtsu fp8000
Width/Sidewall-Diameter (***/**-**): 245/35
If lowered (amount): none
Getting 20 inch tires and was womdering the beefiest tire set up with fendors rolled on a stock suspension (05 TL)
Old 08-02-2014, 04:49 PM
  #2675
20s and beefy tires will make the car look horrible.
Offset of "really high" doesn't help us give you a proper tire size. What is the exact offset?
Old 08-07-2014, 04:03 PM
  #2676
Bswain321's Avatar
Questions on Wheels
Wheel Make/Model: varrstoen V2
Wheel Size (**X**):18x9.5f 18x10.5
Wheel Offset (+**):+25f +15r
Old 08-07-2014, 04:41 PM
  #2677
Bswain321's Avatar
Questions on Wheels
Wheel Make/Model:varrstoen ES2
Wheel Size (**X**):F18x9.5 R18x10.5
Wheel Offset (+**):F+25 R+15
If lowered (amount): 1.5"
Old 08-07-2014, 06:05 PM
  #2678
Originally Posted by Bswain321
Questions on Wheels
Those rear specs are really aggressive. You'll need to roll your rear fenders and stretch tires. 225/40 up front and 235/40 rear.
Bswain321 (08-07-2014)
Old 08-07-2014, 06:15 PM
  #2679
Bswain321's Avatar
I'm ok with a little stretch. What about camber ? I don't want to be running a bunch of negative camber. A few degrees I'm ok with.
Old 09-01-2014, 06:08 PM
  #2680
Bswain321's Avatar
Questions on Wheels
Wheel Offset (+**): trying to find a good offset
Car: 08 type s w/brembos
Quick Reply: D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
