D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
Old 06-09-2013, 08:13 PM
  #2521
Alex Pham's Avatar
Originally Posted by k1x
all the way around? yes it would work with rolled fenders. also depends on the drop and camber settings. i would recomend 225/35 but u might get away with 235 some tires run wider/narrower than others.
Sorry yes all around. Would I need a camber kit in the front? I just have rears
Old 06-10-2013, 01:09 PM
  #2522
k1x
rocking my vs-sexx!!!
k1x's Avatar
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/do-i-need-camber-kit-606757/
read up on this.. it really depends on how much drop you are going for, rule of thumb on most of us here is 2" drop il get a camber kit.
Old 06-13-2013, 11:00 PM
  #2523
weaksauces's Avatar
Fitment on 2007 Base TL
Hi all,
Longtime lurker.....saw some rims for sale online locally and would like to get a second set so I can have a dedicated winter set. I am not too familiar with wheels/tire fitment, so any help would be appreciated. I have a 2007 Base TL, completely stock.
Wheel Make/Model: Drag DR37
Wheel Size (**X**): 18x8.5
Wheel Offset (+**): +40mm
PCD (?): 5/120
Bore (?): 72.56 mm
Tire Make/Model: Michelin Pilot HX MXM4
Width/Sidewall-Diameter (***/**-**): 245/45R17
The person had them on their 2009 TL which makes me think they won't fit, but it is a good deal and wanted to confirm whether they would fit or not.
Thanks!
Old 06-14-2013, 12:19 PM
  #2524
weaksauces's Avatar
Correction to my above post, the tires are 245/45R18.
Old 06-18-2013, 03:38 PM
  #2525
onesiktl's Avatar
Whats Up Guys, Im looking to Purchase some VarrstToen Es7 Wheels this friday.. Looking at getting some 18x9.5 +22 offset Wrapped on some 225/40/18's Dropped on Tien SS. looking for a fresh look. Im aware that ima need atleast a 3mm spacer in the front. anyone have pics of a similar setup on this? should i use spacers on the front and rear? Helpp please
Old 06-21-2013, 01:30 AM
  #2526
dio07TL-S's Avatar
Hey everyone! Think this is an awesome thread! Here is what I have in mind and I am open for any suggestions (not set in stone!)
Wheel Make/Model: WORK Gnosis HS203 (might switch to the new CV202 - It's growing on me)
Offset: +30 (they can adjust to pretty much any offset you request, so this is one of the bits of info I am interested in suggestions the most)
CAR
07 TL-S (Auto)
Currently on stock suspension but interested in dropping it slightly (1/2 to 1 inch, nothing crazy as I dont want to destroy the ride quality)
TIRES
Looking to keep somewhat of a beefy tire on the wheels... looking for at least a 235/40
The car is my daily, so it sees quite a bit of wet roads here in florida, so would like to have a all-season tire. As much as I enjoy "spirited driving", the car is an automatic haha... and I never really put it through much stress.
The only other thing I would have for input is a tire that is still pretty quiet.
Thanks for your help guys!
Old 06-21-2013, 08:42 PM
  #2527
k1x
k1x's Avatar
^your good on your specs nitto motivos and conti dws are the top all season tires here
i think the motivos are quieter than dws
Old 07-03-2013, 09:57 AM
  #2528
7th Gear
Carbin3's Avatar
Hey everyone,
I am looking to get the MRR GT1 19x8.5 (5x4.5/114.3) 35 offset all the way around with toyo proxes tires 245/40/19.
I have an automatic 2008 Acura TL Type S with brembos and have eibach springs installed (1 inch drop).
Will this fit? Or any recommendations?
Any advice would be much appreciated!
Old 07-08-2013, 09:23 AM
  #2529
7th Gear
Carbin3's Avatar
Can anyone help? ^^
Old 07-11-2013, 01:01 AM
  #2530
nvasion's Avatar
hi guys im looking at a set of wheels.. 18X8.5 with +25 offset
Will it fit my 2006 acura tl automatic with 245/40r18 tires without rolling fenders?
thanks
Old 07-14-2013, 12:13 AM
  #2531
simplymatt's Avatar
will these fit.. 17x8.25 +35 on 06 tl with stock suspension for now but will be getting coilovers down the road and plan on dropping 1.5, plus can i use my stock tire size since they are basically brand new?
Old 07-15-2013, 07:50 PM
  #2532
speedy4ever's Avatar
Question on Brembo/Big Brake Clearance
Transmission (Manual or Auto): Auto
Year/Trim (04-07, Base or Type S): 07 Base with Brembos off an 08 Type S
Wheel Make/Model: Work Emotion XD9
Wheel Size (**X**): 18x10
Wheel Offset (+**): 18
If lowered (amount): 24in from floor to center of wheel well
just need to know if they will clear brembos and possible amount of camber needed.
Old 07-17-2013, 09:24 PM
  #2533
LOVEFORMYACURA's Avatar
Any help would be great.
Questions on Wheels
Wheel Make/Model: yoshihara dy-37c
Wheel Size (**X**): 18x9
Wheel Offset (+**): +25
If lowered (amount): not too sure yet but i have suspension on hand though.
So my real question is will this wheel work for my 04 tl without rolling the fenders? I'm pretty sure it will clear the rears but what about the fronts? Thanks!
Old 07-20-2013, 11:58 PM
  #2534
allwhit3g's Avatar
Transmission (Manual or Auto):manual
Year/Trim (04-07, Base or Type S):06 base
Wheel Make/Model:Rotiform nue
Wheel Size (**X**):18x9.5
Wheel Offset (+**):25 or 35
If lowered (amount):I plan on being low low
My question is which offset is a better choice/fit and what tire size I was thinking 215/35?
Going for that flush look
Old 07-27-2013, 11:52 AM
  #2535
blackpearl312's Avatar
Transmission (Manual or Auto):auto
Wheel Make/Model: Enkei Rpf1
Wheel Size (**X**): 17x7 5x114.3 on a 215 tire
Wheel Offset (+**):35
If lowered (amount):1.7 drop in the front 1.5 in the rear
Old 08-15-2013, 08:55 AM
  #2536
savedsols's Avatar
Transmission (Manual or Auto): 6 Speed
Year/Trim (04-07, Base or Type S): 05 with Brembos
Wheel Make/Model: TSW MAX
Wheel Size (**X**): 17X9 front and rear
Wheel Offset (+**):they have a 20 and a 40 ???
If lowered (amount): Eibach pro kit 1"
just need to know if they will clear brembos and if ill need to roll fenders and what tire size do you guys recommend.
Old 08-15-2013, 12:58 PM
  #2537
jpm3071's Avatar
Hey guys!
So went to auto cross the other day and saw a girl with an Audi TT put bigger tires on her stock rim and then used spacers so they wouldnt rub. Has anyone seen this before on the TLs?
Old 08-20-2013, 03:39 PM
  #2538
S2kTl6's Avatar
Hey was wondering if a set of 19x8.5 Volk Racing CE28N with +43 offset all around would fit my 04 Tl with brembos? Haven't seem a clear answer anywhere and just wanted to make sure.
Old 09-25-2013, 12:45 PM
  #2539
JAH Bless's Avatar
Need Help Deciding On Wheels
Wheel Make/Model: Ruff Racing 19x8.5 +35 OR 19"x8.5" 5x114.3 Axis Shine wheels +35 offset
I have a 2004 6MT with no suspension mods. No coilovers, springs, camber kit, etc. Straight stock. I was wondering if either of these wheels would fit without modification and what would be the recommended tire size to run. Any and all help/input is greatly appreciated.
Old 09-26-2013, 01:31 PM
  #2540
6th Gear
sweendogie's Avatar
Questions on Wheels
Year: 04
Transmission: Manual
Wheel Make/Model: MB Battle
Wheel Offset (+**): +30
If lowered (amount): Stock height
I've been searching for awhile and can't find a lot of information on these. I'm visiting my brother and I found a set used with 225/40 tires that I'm looking to buy. Need a response as soon as possible as I am heading home this weekend.
Old 09-26-2013, 01:37 PM
  #2541
CLtotheTL32's Avatar
Received 9,528 Likes on 6,183 Posts
Both should fit fine and you should run 245/35/19 tires.
Originally Posted by sweendogie
Questions on Wheels
Year: 04
They will fit!
Old 09-26-2013, 07:07 PM
  #2542
dieselsaint88's Avatar
Wheel Make/Model: Rota Grid
Wheel Size (**X**): 17x8
Wheel Offset (+**): +35
If lowered (amount): about 2 inches
Wheel Make/Model: Enkei RPF1
Wheel Size (**X**): 17x9
Wheel Offset (+**): +45
I drive a 2003 Acura tL, lowered about 2 inches. Thanks.
Old 09-26-2013, 11:18 PM
  #2543
jauman's Avatar
Base TL
Year: 08
Transmission: AT
Wheel Make/Model: Vossen CV3
Wheel Size (**X**): 19x8.5
Wheel Offset (+**): +32
Tire Size: 245/35/19
Five Questions (all in reference to the above wheel and tire size):
1st - Will they fit my Base TL, stock height, without rubbing?
2nd - would they still fit without rubbing if I lowered it .75-1" with A-SPec suspension.
3rd - Would I need an alignment.... would I need a camber kit (if I lower it)
4th - Would I be able to run Stop Tech Big Break Kit, or EXRL8 Big Brake Kit?
5th - Anyone know if I can use the stock TPMS with the Vossen CV3?
Thanks!!!
Old 09-28-2013, 09:32 AM
  #2544
Acura drove me away too..
BlueAc's Avatar
Long shot but will these wheel specs fit my 07 TLS:
(2) 19x9.5 +25 (R-Disk)
(2) 19x10.5 +25 (O-Disk)
Bolt pattern: 5x114.3
Not dropped right not but will be ordering ISC coilovers very soon. Also, how do you guys determine what will and will not fit? Thx
Old 10-10-2013, 01:49 PM
  #2545
nostra's Avatar
Questions on Wheels
Wheel Make/Model: OZ
Wheel Size (**X**): 17X7.5
Wheel Offset (+**): 42
If lowered (amount): None
Tire Size: 235/45/17
Old 10-13-2013, 08:13 AM
  #2546
WAngel's Avatar
Hey guys I'm looking to get done wheels and need to know if a +24 on a 18x9 5.95" backspace front will clear my brembo. Rears are 18x10 +22 6.36" backspace I want to run a 225 40 front and 235 40 rear. I don't mind camber just a bit as I'm planning to get a kit but will I have to roll? As I'm really not trying to risk fucking up my MRP type S. Any help would gladly be appreciated. My drop is unknown at the moment being stick height but I'm planning to drop about 2.5" in the front and 2" in the rear.
Old 10-15-2013, 12:22 PM
  #2547
blah
Vietnastee's Avatar
With these specs you're going to have to roll your fenders and run negative camber.
The fronts will fit with some 225/35 stretched tires and some negative camber. Only problem you will run into is that metal tab on the fender where the fender and bumper meets. You're going to have to shave this down or else it's going to cut into your tires.
The rears will also fit with stretched 245/35 tires and negative camber (my guess is from -3 to -5 degrees depending on your drop and the look you're going for). You can run a 235/35 tire for more stretch so you can use less negative camber, but I personally feel 245/35 on a 10.5 is a safer stretch. I am just unsure if the inner part of rim will rub against the coilover if you run too much negative camber. (Check out Nitrous's post on his vs-xx when he ran a 10.5+29 in the rear: https://acurazine.com/forums/showpos...8&postcount=77)
Maybe someone with 19x10.5 rear wheels can comment?
Old 10-16-2013, 02:29 AM
  #2548
jauman's Avatar
Base TL
Year: 08
Transmission: AT
2nd - would they still fit without rubbing if I lowered it .75-1" with A-SPec suspension. (25" ground to wheel well est.)
3rd .... nvr mind
4th - Would I be able to run RB BBK (11.8 rotor)? ... clear calipers
Thanks!!!
Old 10-17-2013, 08:38 PM
  #2549
cipher9878's Avatar
Base TL
Year: 04
Transmission: mt
Wheel Make/Model: XXR 531
Wheel Size (**X**): 19x8.5 FRONT 19X10 REAR
Wheel Offset (+**): +15 FRONT +32 REA
If lowered (amount): Stock height (for now looking to drop in a week)
Tire Size: 225/35/19 front 255/35/19 rear
Will i need to roll my fenders before i drop?
Will i need spacers to clear the brembos?
what tire size would i need to get minimal stretch in the back?
Old 10-23-2013, 09:09 PM
  #2550
Team Anthracite President
Vffr1's Avatar
I have an 07 TL Type S.
I would like to get a 2nd set of stock "TL" wheels for track days, will regular TL wheel fit over the Type-S Brembo brakes such as the stock 2004 5 star or any of the other offerings, like the 2007 TL base wheels)?
Also, I plan on running track specific tires and was thinking of going with 245/35/17, would you suggest a better size for track days?
Thanks,
Triple
Old 10-26-2013, 05:29 PM
  #2551
bennettm89's Avatar
Gonna follow the format provided in post#1 and hope it nets me a response:
Questions on Wheels
Wheel Make/Model:"C-LM Replica"
Wheel Size (**X**):18x8
Wheel Offset (+**):+35
If lowered (amount):1.5"
Transmission (Manual or Auto): Automatic
Year/Trim (04-07, Base or Type S): 2007 TL Type S
Wheel Make/Model: "C-LM Replica"
Wheel Offset (+**): +38
If lowered (amount): 1.5"
Here's a link to the wheels:
http://unleashedwheels.com/c-lm-style-wheel.html
Any advice PM'd or replied is appreciated.
Old 10-26-2013, 05:48 PM
  #2552
blah
Vietnastee's Avatar
Those will not fit without a spacer. You will need to run a spacer to clear the Brembos in the front.
Old 10-30-2013, 04:50 PM
  #2553
5th Gear
Smooth06's Avatar
Questions on Wheels
2006 Base Model
Wheel Make/Model:BBS LM Reps (Possibly Varrstoen ES1's) Hyperblack with Polished Lip
Tire Size: 235/40/18
If lowered (amount):Currently Stock, waiting for Tein Street Flex to be available in which case i will go around 2" lower or less.
Hope i will not have to roll fenders, or camber Kit.
Thanks for the info acurazine!!
Old 10-30-2013, 11:07 PM
  #2554
3rd Gear
tbenson's Avatar
Wheel Make/Model: ground force gf07
Wheel Size (**X**): 18x9 all around
If lowered (amount): aspec suspension
Transmission (Manual or Auto): auto
Year/Trim (04-07, Base or Type S): 08 base
I want to run a 245/40r18 all the way around and just curious if there will be any rubbing issues? Thanks in advance to whoever can help.
Old 11-02-2013, 07:54 AM
  #2555
a huhhhh
Old 11-03-2013, 04:30 PM
  #2556
Marcus204's Avatar
Base TL
Year: 06
Transmission: AT
will these wheels/tires rub? can i fit them without doing any further modifications? if not what will i have to do.. thanks!
Old 11-03-2013, 04:32 PM
  #2557
Marcus204's Avatar
^^ apologies..^^ i meant wheel size 19x9.5. just got my new tl and cant wait to throw some rims on! thanks for helping me out
Old 11-03-2013, 05:58 PM
  #2558
jauman's Avatar
Vossen only makes CV3 19's in 8.5 +32 and 10 +38 or +20.
If you have 9.5 +35 i'm not sure their genuine.
Old 11-03-2013, 06:02 PM
  #2559
jauman's Avatar
Base TL
Year: 06
Transmission: AT
I have
Year: 08
Transmission: AT
Wheel Size (**X**): 19x8.5 (fr) 19x10 (rr)
Wheel Offset (+**): +32 (fr) +38 (rr)
Tire Size: 235/40/19 (fr) 245/40/19 (rr)
They fit my TL no rubbing.
Old 11-05-2013, 10:05 AM
  #2560
04 Acura TL
shotta's Avatar
Transmission (Manual or Auto):Auto
Year/Trim (04-07, Base or Type S):04 base
Wheel Make/Model:Miro 398
Wheel Size (**X**):18x9.5 michelin pilot sport a/s plus 235 40 18
Wheel Offset (+**):34
If lowered (amount) FNF type 1 2.5 to 3
Quick Reply: D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
