Bolt pattern
Bolt pattern
Will rims that fit a 2005 mitsubishi eclipse fit a 2004 Acura TL? Buddy of mine just bought some 20 inch Zinik Z17 Caroza rims for his car. After putting them on his car he didn't like them. So now he wants to sell them to me for 350 bucks. They were on his car for a half day.
Is there anyone running the Zinik Z17 Caroza rims on their TL? I would like to see what they look like.
I just did a quick google search and found
2005 Mitsubishi
Eclipse
Bolt Pattern: 5x114.3
Center Bore: 67.1
Hardware:12x1.50 Lug
Offset: 34-42mm
So is the TL's bolt pattern 5x114.3 too? If so I might get these rims. You think $350 is a good deal?
2005 Mitsubishi
Eclipse
Center Bore: 67.1
Offset: 34-42mm
You're going to need hubcentric rings since the center bore is too large on that wheel. if it fits the Eclipse, it has to be at least 67.1. The TL has a 64.1 bore.
Measure the bore of the wheel and get a hub ring that will reduce the bore size down to 64.1. Vibration may occur if you don't install hub rings.
neuronbob
23
07-16-2019 10:48 AM
