Anyone running 255/40/18's and lowered?
I should have my A-spec wheels/suspension by this time next week and want to get the tires ordered now as well. I'm torn between the 245/40/18's and 255/40/18's. I've seen some have run the 255, but after all of my searching the archives I have yet to fund someone lowered running this combo?
Any insight is appreciated.
Thanks,
Travis
Thanks,
Travis
ImayBparanoidButNoAndroid
To me it just seems like 255's is overkill considering the stock A-Spec 18's are 235. My guess is that with the 255's on the A-Spec wheels and suspension you won't have a rubbing problem but it is just a guess. Good luck.
Need More HP!!!
255/40/18's
I upgraded to the a-spec 18's (8.5" wide).
If you are getting the 8" new ones, 255's will work but for me would offer too much flex w/255's.
the 245/40/18's are perfect for the 18 8 1/2's. just right.
the 235/40's on the 8's will scar your rims just like the 17" stockers did with 235's.
If you are getting the 8 1/2's, the 255 will be fine, but I like the 245's..
Thanks,
Travis
maybe a prob w/the comptech's but I do not think so..
I will likely be lowering with Comptech's (because I really like how the drop looks, and everyone comments on the 'near stock' ride).
So, you think the 255's on either comptech or A-spec would clear (do you think you've got that much clearance inside and out)? (obviously it's a bit of a guesstimate)
Thanks again for your help,
Travis
I installed the 255s on the 8.5" genmetal TL rims. No problems at all. But I did not install A-Spec springs that will lower the car 1/2". You are asking about the difference essentially between the 245 vs 255. The width difference between the two sizes is about 1/2". The overall diameter difference is 3/10". These are very small increases. Remember the A-Spec springs are stiffer than stock and the rebound rate won't be as much as stock. Not having heard if anyone has done what you are proposing I really don't think you will have any problems.
I appreciate your input though, thanks for the post. Have you looked behind the wheel to see what kind of clearance you have for mechanicals/shocks/etc.? 1/2 - 1" is quite a bit to lower, this is my concern.
Thanks!
Travis
Originally Posted by tgt
I'll agree with you that those are both small changes, but I'll use the example of trying to find wheels to fit over the Brembos on a 6MT, a VERY SMALL (just a few mm) and bam, it's all over.
Thanks!
Travis
Thanks!
Travis
1fatcrxnem1
22
06-01-2018 01:23 AM
