wiper fluid motor dead ???
Old Dec 4, 2008 | 05:41 PM
MaCe's Avatar
fellow MASShole
washer fluid motor just crapped out the other day ... no noise nothing coming out taking it to get looked at
cars an 04 .. 55k this a common problem ?
MaCe
Old Dec 4, 2008 | 08:56 PM
DanL's Avatar
Haven't heard about that happening before, but it's not too hard to replace yourself (believe you need to remove to inner fender well liner to get to it though). The OEM part is $50 on-line ($60 or so from most dealerships) and aftermarket ones are about $25.
Old Dec 5, 2008 | 09:46 PM
nfnsquared's Avatar
MaCe
Check your rear view mirror. Is the green light on? If not, you just blew a fuse. There is a TSB to change the original fuse from a 7 amp to a 10 amp fuse on 04 TLs. Happened to me once as well. Has not happened since I upped the fuse amperage.
http://www.in.honda.com/Rjanisis/pubs/SB/B05-033.PDF
Old Dec 7, 2008 | 01:26 PM
Zigma's Avatar
you prob blew a fuse, like stated, check if you can move your mirrors as well. Happend to me.
Old Jan 18, 2009 | 05:27 PM
Crazyace718's Avatar
Thanks for the great advice. I just had the same problem and your instructions worked perfectly.
Old Jan 18, 2009 | 06:37 PM
ssmtl2nv's Avatar
2009 g37s 6mt
has the weather been rather frigid lately. My fluid was frozen the past few days and gets back to normal when the weather warms up. Look into it anyways.
Old Jan 18, 2009 | 07:00 PM
mrempp's Avatar
my mirror and washers didn't work either the other day. Changed the fuse and it was back to normal.
SidhuSaaB
May 30, 2020 12:40 AM
08KBP_VA
Oct 22, 2019 01:55 PM
Houston
Oct 8, 2015 01:27 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
