Window wipers, stopped working.?
Old Sep 4, 2009 | 04:33 AM
JayPTL04's Avatar
2004 TL !!
my window wipers stopped working all of a sudden.. what can be the problem, i can spray.. but i cant wipe..
Old Sep 4, 2009 | 05:00 AM
tsx-pwp-nj's Avatar
2010 TSX 5AT PWP
That happened on my 2001 Accord last year. Had to replace the wiper motor. Simple job, picked one up at a junk yard for $25.
Before doing that, check your fuzes.
Old Sep 4, 2009 | 10:08 AM
Will Y.'s Avatar
Registered but harmless
1) Was your TL part of the wiper motor recall? If so, was the recall performed or not? If your car is part of the recall but did not have the work done, go to the dealer and have it do the work (recall work is free here in the US, even if the warranty has expired-- call the dealer before going and check on that as well if the recall applies to your car).
2) Check fuses if your TL is not part of the recall or if the wiper motor recall work was done.
Old Sep 4, 2009 | 10:56 AM
LoveMyTL-S's Avatar
Here's the link for the recall:
http://www.in.honda.com/Rjanisis/pubs/SB/b08-013.pdf
Old Sep 20, 2009 | 08:50 PM
JayPTL04's Avatar
2004 TL !!
i have no clue what this "recall" is
Old Sep 20, 2009 | 11:28 PM
Will Y.'s Avatar
Read the post above yours (post #4)- then click on the link that starts, "http...".
Old Jan 11, 2011 | 06:23 PM
mc_holla's Avatar
I'm having a similar problem as the OP as my wipers also will not work. What Im thinking happened was last night I turned ca off with wipers on, so this morning when I can out to warm my car up (was covered in about an inch of ice and wipers were buried), I guess the wipers burned themselves out. Has this happened to anyone and what would you say I messed up?
***Fuse #11 is fine
***Already had recall done
***No movement or sound at all.
Thinking its the relay (not sure where it located) or the motors.
Thanks,
Marlon
Old Jan 13, 2011 | 08:24 PM
mikedog4's Avatar
Why me??
broken linkage? or wiper arm nut(s) not tightened? with frozen wipers those are the first things id check.
Old Jan 14, 2011 | 09:09 PM
mc_holla's Avatar
Thanks. Will be checking it out tomorrow. Does anyone with experience replacing those parts have any insight?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
