Window Regulator replacement
Old Aug 8, 2018 | 07:34 PM
ReD-BaRoN's Avatar
Hey folks,
From what I can tell, most of the 3G garage posts are busted.
I need to replace the window regulator in my passenger side door. Do I need the whole contraption, or just the motor?
Old Aug 9, 2018 | 07:17 AM
08KBP_VA's Avatar
Havent wrenched on regulator for Acura yet for regulator but if its just regulator then you can usually just transfer the motor to new regulator. Ill let a techie who has done it in TL respond for better insight though.
Old Aug 9, 2018 | 10:55 AM
BreezyTL's Avatar
I would replace the whole thing. I don't know if you can just buy a motor but the cables could be worn and snap shortly after, who knows. Just my
Old Aug 9, 2018 | 11:01 AM
BreezyTL's Avatar
These are very easy to replace yourself. I would purchase thru the links below as your local dealer will most likely be higher! (Mine wants $203 for the front passenger regulator and $184 for the rear passenger regulator)
Front Passenger Regulator Assy
https://www.acuraoemparts.com/oem-pa...9tYXRpYw%3D%3D
Rear Passenger Regulator Assy
https://www.acuraoemparts.com/oem-pa...QtYXV0b21hdGlj
Old Jun 9, 2019 | 11:26 PM
Imadreamer's Avatar
Same problem here. Mine just won’t roll down but I can hear the switch click so I’m assuming it’s regulator/ motor.
Old Jun 10, 2019 | 01:27 AM
01acls's Avatar
Op,
You have to replace the whole assembly, motor and regulator. You can save a lot of money by using recycled parts, especially if you pull the parts yourself at a local pick n Pull... $40.00.
Old Jun 10, 2019 | 08:20 AM
BreezyTL's Avatar
I have a driver front and rear for cheap. Let me know if anyone needs one.
Old Jun 10, 2019 | 10:16 AM
Imadreamer's Avatar
I would be interested but I don’t have PayPal
Old Jun 10, 2019 | 10:23 AM
BreezyTL's Avatar
Set one up and I can ship it to you. Roughly 2-3 day shipping based on location.
Old Oct 7, 2019 | 01:21 PM
Slpr04UA6's Avatar
-------Tim-------
Has anyone sourced or tried a window regulator from eBay? Is it worth the money for OEM? Also found one on rock auto, for $30! Much cheaper than $148 OEM from dealer......Thnks!
eBay link below:
https://www.ebay.com/itm/Front-Left-...Display%3A3.2L
Old Oct 7, 2019 | 01:30 PM
rock auto is fine! I wouldn't do eBay
Old Oct 7, 2019 | 01:48 PM
Slpr04UA6's Avatar
-------Tim-------
So for drivers side it would be front Left, correct? I know it depends on if you’re facing the vehicle I believe. I guess the motor is separate? Darn! My motor works some, slowly. And stops 1/2 way down. Haven’t popped door panel yet to check to see what’s broke, but heard a clunk, when window was lowered all the way down. Then won’t go lower than halfway now. Don’t want to try again, and have it not go back up....
Old Oct 7, 2019 | 01:50 PM
BreezyTL's Avatar
Those look like they are just the cables, no motor.
Old Oct 7, 2019 | 01:55 PM
Slpr04UA6's Avatar
-------Tim-------
I noticed that after I posted. Looked up the motor as well. Then it looks like total for both would be ~$100.....OEM from dealer is $148.20
Old Oct 7, 2019 | 04:24 PM
it could just be slow because the regulator is broken and providing extra resistance on the motor; ergo, the motor COULD be okay. I'd buy both just to be safe and you can return it if you determine the existing motor is still alright.
Old Oct 7, 2019 | 04:48 PM
Slpr04UA6's Avatar
-------Tim-------
True, I’ve thought about that aspect. My only concern is that I have the KP module soldered in, and I can’t recall if I’ll be able to pull the panel far enough, for access. It’s been a long time since I’ve had to go in there....
Old Oct 14, 2019 | 08:20 AM
BreezyTL's Avatar
Do it then let me know where the wires go. I'd like to get mine installed.
rlawson
Oct 7, 2019 03:10 PM
floridatom
Feb 24, 2011 12:07 PM
wuiwui85
Mar 17, 2009 11:59 AM
STL+3.0CL
Sep 23, 2006 10:49 PM
MultiBeast
Apr 5, 2006 03:05 PM
