whats wrong with my car :(
Old Aug 2, 2010 | 11:44 AM
Alaa123's Avatar
6th Gear
Unhappy whats wrong with my car :(
hello everybody,
i just bought a used '04 Acura TL that came with a lowering kit and i love it!
the only problem is that when i hit the brakes it pulls to the right
i had an alignment done, calipers checked and my mechanic told me that he cant find whats wrong with it.
can anybody help me, PLZ!!!
Old Aug 2, 2010 | 06:04 PM
YeuEmMaiMai's Avatar
bleed your brakes
Old Aug 2, 2010 | 09:36 PM
LiquidLunch's Avatar
Find a quality alignment and balancing shop with a Hunter GSP 9700 wheel balancer. Road force balance your tires.
Old Aug 2, 2010 | 10:53 PM
Alaa123's Avatar
6th Gear
whats the bleeding gonna do?!
and to be honest with you guys, i kinda think that my mechanic isnt all that. i might have 2 get a 2nd opinion on the caliper
Old Aug 3, 2010 | 12:06 AM
if you got air or moisture in the system then one front brake is going to pull the car more than the other.......and you will get a hard pull to one side as described.
Old Aug 3, 2010 | 07:04 AM
Turbonut's Avatar
^And/or, bad hose or caliper.
Old Aug 3, 2010 | 03:29 PM
Alaa123's Avatar
6th Gear
i did the brake bleeding and nothing happened!
checked the caliper at a different mechanic and he said the caliper is pretty good
i still dont know what causes the car to shift to the right when i hit the brakes
maybe i wasnt clear in the beginning when i said "pull to the right"
its not a hard pull, it just shifts to the left easily
Old Aug 3, 2010 | 03:30 PM
Alaa123's Avatar
6th Gear
i meant to the right
Old Aug 3, 2010 | 04:17 PM
lilsid112's Avatar
+1 The piston was seized in the caliper in our suburban, which caused it to pull only when applying the brakes.
Old Aug 3, 2010 | 07:34 PM
Alaa123's Avatar
6th Gear
all 4 pistons are working just fine on the caliper
Old Aug 4, 2010 | 06:57 PM
Alaa123's Avatar
6th Gear
could it be a suspension problem?!
if so, what exactly?!
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
jordanboi
Sep 5, 2015 01:33 AM
SUPRMN84
Sep 2, 2015 11:50 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
