What is this hole?
Old Jan 20, 2026 | 05:43 AM
mariusz439's Avatar
What is this hole?
My mechanic disassembled the transmission again as despite changing rear main seal I still had the leakage. He checked it and says it seats correctly and there is no leakage around. However he noticed a hole just above the torque converter cover and it looks like the oil is leaking from there.
What is this for? Is there anything missing?
Old Jan 23, 2026 | 02:57 AM
mariusz439's Avatar
Aby idea 💡?
Old Jan 24, 2026 | 03:09 AM
mariusz439's Avatar
Have done some additional research. And it seems nothing is missing there. However the question what is it for still remains.
Old Jan 27, 2026 | 12:44 PM
t-rd's Avatar
That hole is nothing, but there is an o-ring right below it, behind that cross print, behind large aluminum plate.
Old Feb 2, 2026 | 06:23 AM
AMTMJ's Avatar
I believe that is a valley drilled in the block that leads from the area in between the cylinder heads to allow for drainage. Also, there is an oil passage o-ring above the rear main seal (behind the cover plate) that tends to leak. Both the rear main seal and the o-ring should be replaced to avoid having to go back in there, along with resealing the cover plate with Honda bond.
Old Feb 16, 2026 | 11:18 AM
mariusz439's Avatar
Originally Posted by AMTMJ
I there is an oil passage o-ring above the rear main seal (behind the cover plate) that tends to leak.
Can you please show me it on the diagram. I cannot find the number. My mechanic reseated the rear main seal, however it seems the oil still drops under the car.
Old Feb 16, 2026 | 11:37 AM
This is were it goes on the rear cover plate above the rear main seal.
Old Feb 16, 2026 | 11:43 AM
mariusz439's Avatar
Perfect, thanks.
1,63$ and third disassembling of everything . Damn.
Old Apr 11, 2026 | 07:18 AM
mariusz439's Avatar
The o-ring replaced. Unfortunately it seems the oil is still leaking....somwhere 🤷
I'm a little bit tired with this issue. Especially that it seems my mechanic again overfilled the tranny and need to take care myself.
arek1200
6G TLX Problems & Fixes
Nov 1, 2025 09:05 PM
hotsnowman
Dec 1, 2024 02:43 PM
altair47
4G TL Problems & Fixes
Apr 27, 2024 04:17 PM
robster80
Jun 12, 2023 07:18 AM
TheMightyQuinn
Sep 21, 2020 04:36 PM
