Weird noise please help
Old Apr 20, 2011 | 07:03 AM
**WhItE-aNgEl**'s Avatar
So this morning I went to warm up my car. I put the heater on and went bAck inside. I started hearing this weird whorping sound. So I got out and checked. Every 2 mins my fan was kicking in and it would do this weird sound then after 5 secs it shut off. Is this common?
Old Apr 20, 2011 | 07:20 AM
amazo's Avatar
Sounds like your blower motor is going, or could be the blower motor wheel
Old Apr 20, 2011 | 07:21 AM
please explain the sound in great detail...sadly whorping doesnt help.
Old Apr 20, 2011 | 07:46 AM
The sound is similar too when you buy really noisy tires. And the sound they make while your braking. I hear my fan kick in then that sound is in the back ground for like 3 secs then my fan shuts off and the noise goes away. About 5 mins later fan kicks in again and does the samething .
Old Apr 20, 2011 | 07:17 PM
Anyone?
I realized my coolant reservoir is low can that be why?
Old Apr 20, 2011 | 10:42 PM
BAGII's Avatar
With the engine not running and cold, try wiggling the fan itself and see if its loose. the bearing and motor may be going bad. the fan should be tight. compare one fan to the other one next to it.
Old Apr 21, 2011 | 07:40 PM
eg5's Avatar
eg5
user title goes here
first of, when you warm your car, its the a/c on? note next time u do it.
it could be a bad a/c tensioner or a faulty compressor.
i doubt the fan would do such noise. it'll have to rub on something in order to make that noise. check the fans(engine off)to see if they wobble. keep us updated
Old Apr 23, 2011 | 09:08 AM
No my A/C isn't on. And Its not my fan. It's my compressor. It makes this really loud sound when it turns on. And then it makes that sound. And shuts off. I thought it was my fan but now that I opened the hood and checked, it's not my fan.
Old Apr 23, 2011 | 09:38 AM
Jesstzn's Avatar
The compressor will cycle as part of taking the humidity out .. mine does it .
Old Apr 25, 2011 | 10:34 PM
eg5's Avatar
eg5
internal compressor failure. to be safe, replace the entire unit. better keep your hands off the a/c button before u seize it and contaminate the entire system
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
