Weird grinding/moaning sound while coming to stop and accelerating (intermittingly)
Old Sep 16, 2019 | 07:46 AM
RedsTL's Avatar
Question Weird grinding/moaning sound while coming to stop and accelerating (intermittingly)
This is the weirdest problem I've had yet, but there's a deep, grinding and/or moaning type weird sound that seems to match the wheel's spin. I thought maybe transmission, but it does it even when remaining in first gear if moving. The weirdest part is that it can sound REALLY BAD, then after driving for a few minutes completely goes away.
Any thoughts? Transmission, CAT, axle, ....there's not enough consistency in what I'm observing for me to have any reasonable ideas. Thanks...
Old Sep 16, 2019 | 08:55 AM
Jackass's Avatar
My initial guess would be failing wheel bearing. Not easy to figure out which one until your find a repeatable pattern.
Old Sep 16, 2019 | 09:13 AM
I would check axles. Maybe a failing CV joint. Check the boots to see if maybe it's cracked/leaking
Old Sep 16, 2019 | 03:56 PM
Michelle Wright's Avatar
Have your mechanic check your Compliance Bushings and/or Wheel Bearings...I hope this helps good luck!
Old Sep 17, 2019 | 12:10 PM
RedsTL's Avatar
First mechanic is saying upper control arm needs replaced.
Old Sep 17, 2019 | 01:36 PM
RedsTL's Avatar
** Finally received full report. They said the Upper Control Arm has a crack and tie rods need replaced.
donaldso718
Aug 1, 2010 09:05 PM
cfive
Jan 16, 2007 12:10 AM
duckman2000
Jan 30, 2006 05:07 PM
Mikes96TL03CLS
1G TL (1996-1998)
Jul 22, 2005 08:04 PM
Sir
Jan 14, 2005 02:45 PM
