VSA on because of tires?
Old Feb 13, 2008 | 01:08 AM
fluxcapacitor3000's Avatar
i bought a used 05 tl aspec but my vsa and the ! has been on, i have recently done balance, brake job, and alignment and its still on. My friend who did everything told me that my tires were worn unevenly, is that the reason why my indicators are on?
Old Feb 13, 2008 | 01:40 PM
neone?
Old Feb 14, 2008 | 11:21 PM
I hate cars's Avatar
If there's a big difference in diameter it will throw it off. Not sure if uneven wear on the same size tires would be enough. There has to be some margin for error or it would go off every time you turn the steering wheel and the outside tires turn faster than the insides.
Old Feb 21, 2008 | 03:23 PM
GLowrdr's Avatar
Don't feed the...WTF?
That's not enough to trip your system. You've got a bad sensor on one of the tires.
Old Feb 21, 2008 | 03:51 PM
Bearcat94's Avatar
AZ Community Team
Ok, dumb question, sorry.
Are sure you VSA isn't "OFF". When VSA is OFF, the light in the dash comes ON and Stays ON.
When VSA is ON, there should be no light in the dash UNLESS VSA/TC Activates (the triangle ! flashes) or there is a problem with the system.
Old Feb 22, 2008 | 12:18 AM
csmeance's Avatar
Have someone press the brakes and make sure the brake lights come on. This could be an indicator of a faulty brake switch. Also is the ABS light on? If not, then it should not be a wheel sensor.
Old Feb 22, 2008 | 01:32 AM
it might be the wheel sensor since the (!) and vsa is on at the same time. when i hit the vsa button, nothing happens. what do u suggest guys?
Old Feb 22, 2008 | 09:28 AM
Jesstzn's Avatar
And this was on BEFORE the brake work?
Old Feb 22, 2008 | 11:50 AM
yea why
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
bryan zaragoza
Sep 8, 2015 12:28 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
