VSA and ABS light on
Old Aug 14, 2014 | 10:20 AM
Fr3shAcuraTL's Avatar
Question VSA and ABS light on
I have a 2005 acura tl and my vsa and abs lights went on. I had just changed the rotors and brake pads like 5 days ago but idint bleed them because i was tired lol. Car brakes good like it was before but idk. Ima have to bleed brakes later on and see if they go off. The lights didnt turn on when i turned on the car they turn on imediately after i put in gear. I might have to go to the dwaler to check the codes. In the mean time if anyone knows what can i do to see if lights go off i appreciate the help.
Old Aug 14, 2014 | 10:51 AM
flyromeo3's Avatar
its either going to be the abs wheel sensor, or wheel bearing.
However, I would lean more towards the ABS wheel sensor.
Go to an autozone or pep boys and borrow their code reader so you can pull the codes. Just make certain it can read ABS codes since not all of them do.
Another thing to check is that the wiring to the abs sensors aren't ripped or anything.
Your brakes will work fine. Only thing is your ABS isn't working.
Since VSA works in tandem with the ABS wheel sensor. IF the ABS sensor cant get a reading it will trigger the VSA light.
I encountered this same problem not to long ago. My problem ended up being the wheel bearing that I must of damaged when I reinstalled my axle.
if you get the codes. Post it so we can help
Old Aug 16, 2014 | 12:20 AM
jkballin's Avatar
Mine ended up being something to do with the brake fluid reservoir. I unplugged the cable going to the reservoir and the parking brake and vsa lights that were on my dash didn't come on any more. Now I just need to see if the float is stuck or I need a new sensor. Hope this helps.
Old Aug 19, 2014 | 03:29 PM
flyromeo3's Avatar
any updates?
Old Aug 19, 2014 | 04:36 PM
YeuEmMaiMai's Avatar
d5 blinking?
Old May 20, 2019 | 11:46 AM
Jami Thomas's Avatar
My vas is on and it shut down my car when I driving
The vas on my car is on I came on and my car keep shutting off what can I do
Old May 24, 2019 | 05:13 AM
DMZ's Avatar
DMZ
Head a da Family
Yesterday, my VSA and ABS lights came on and stay on:
Any thoughts folks?
Old May 25, 2019 | 07:44 AM
DMZ's Avatar
DMZ
Head a da Family
I found the brake fluid was low. So I topped it off then the light went off for about a half a day. Paul found very slow leak in the left rear brake hose fitting which he of course tightened. Then the light came back on. He connected the code reader and came up with an 8401 speed sensor error which he had never seen before. Anyone know how to tell which ABS speed sensor that referred to?
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
