3G TL sudden electrical issues
Hey everyone, I'm not too keen when it comes to electrical issues. However, somehow overnight I've run into some new electrical issues.
1. Key fob no longer works to lock and unlock the car (light on fob still illuminates so battery in fob is not dead)
2. Driver side door interior door lock switch does not work (passenger side still works)
3. Fog light switch does not work
4. Blinkers do not work (hazards work though)
5. When headlights are on, the dash light indicator does not illuminate
6. Headlights do not turn on under battery power only
7. Thermometer to display outside temp in dash display does not work
8. Window controls on driver side do still work (somehow)
All these issues just occurred over night, none of these things listed were an issue as of the day before this post. I've checked all fuses and none of them were blown. Also disconnected and reconnected the battery to reset and that did not fix anything either. So, any info would be greatly appreciated to help.
Change the battery in the fob. It's almost dead.
Take off the driver side door interior trim and check the cable link for the door. It might have broke.
Change the outside temperature gauge.
Skunkworkz
1G RL (1996-2004)
Mar 3, 2015 05:57 PM
