wiring harness
Old May 25, 2019 | 02:51 PM
mswags's Avatar
4th Gear
wiring harness
I just replaced the transmission in my 04 TL. no lift so in order to do this i had to pull the engine/tran out the top. after getting it back in and the wiring hooked up I have no power and it is acting like its crossed when i try to jump it. rechecked all connector and grounds and everything seems to be normal. Any idea
Old May 25, 2019 | 05:19 PM
mswags's Avatar
4th Gear
ok so i jumped it straight to the power in spot on the fuse box and it gets power. loosened the bolt that connects the power cord to the started and it works fine. tighten the bolt down and it fries. completely at a loss. just kept the bolt only half tightened and it works fine for now. until it jjggles lose.
TLdriver022
Oct 26, 2006 07:51 AM
01cl_blk
Mar 13, 2006 08:12 AM
