valve tapping/knocking? engine light on
Old Jun 16, 2009 | 08:24 PM
AckTL05's Avatar
Former Sponsor
Cool valve tapping/knocking? engine light on
I recently was told that I have a valve tapping, if you put your hand over the vavle when the engine is on you can feel that the middle valve is messed up says one. Yesterday I was driving and then the engine light came on and the car just started to boggin out and someone asked if i had an exhaust leak because it sounded like the exhaust was popping/studdering when I reved it up. Does anyone know what is wrong. Mind you the valve noise has been going on for one year and i never had anything but premium gas and no water damage. The only mod is an intake to the engine. I change my oil and filter every 3k miles with mobile one synthetic. Please help!!
My car is an 05 with 49k miles.
Old Jun 16, 2009 | 08:37 PM
Turbonut's Avatar
Is there oil in the car?
Being an '05 and depending on the in service date, I guess it's out of warranty, unless it was a CPO vehicle.
If covered under the warranty take it to the dealer.
Old Jun 16, 2009 | 09:27 PM
AckTL05's Avatar
Former Sponsor
always had oil and warantee just expired.
Old Jun 16, 2009 | 09:36 PM
Turbonut's Avatar
Take it to AutoZone and have them read the code.
Old Jun 16, 2009 | 09:50 PM
AckTL05's Avatar
Former Sponsor
well i have my mechanic looking at it saturday but i was wondering what the problem is because now the engine is like bogging out and do you know how much it is to read the code? Also, is it safe to drive it there?
Old Jun 16, 2009 | 10:15 PM
phee's Avatar
I got the Shifts
autozone reads codes free. i wouldnt drive the car more than needed. you can do a lot of damaged with a damaged valve
Old Jun 18, 2009 | 11:24 PM
Inaccurate's Avatar
Is your car an automatic transmission or 6-speed manual ?
Old Jun 19, 2009 | 05:18 AM
SouthernBoy's Avatar
Registered Member
Says one what? How did he put his hand over the valve? Did he removed a valve cover to get to it? Keep in mind, you have 24 valves. Couple of questions, please.
o Are you the original owner? If so, did this develop slowly or suddenly and if suddenly, what did you do to bring this about?
o Do you hear the sound at all normal engine speeds?
o Do you hear any sort of rattling coming from the engine area, kind of like keys rattling in a can?
Definitely either buy a hand-held diagnostic code reader or have your codes read to see what gives.
Old Jun 20, 2009 | 12:08 AM
Inaccurate's Avatar
SouthernBoy,
You forgot one other question.
o Is this a 6-speed trans and did someone maybe grab a lower gear instead of a higher gear ?
Old Jun 20, 2009 | 04:01 AM
Trooper04's Avatar
6th Gear
if the engine was off and you were feeling the valve, make sure that cylinder is at TDC on the compression stroke.
Old Jun 20, 2009 | 09:29 AM
Registered Member
Originally Posted by Inaccurate
SouthernBoy,
Old Jun 29, 2009 | 02:16 AM
AckTL05's Avatar
Former Sponsor
it was actually a loose spark plug and it was tapping?!?!? werid but replaced with all brand new plugs and worked great/ no more "pinging" the best part was i took it to acura and they said it was the "compressor".
Old Jun 29, 2009 | 05:12 AM
Registered Member
Whoa. That doesn't speak too well for their techs.
Glad it was something as simple as that.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
