Upper intake butterfly valve
Old Jul 13, 2020 | 07:26 PM
6for2's Avatar
Bought a 2007 Type-S recently, and it runs poorly. I'm replacing a few things to try to make it run better, but right now I am going to adjust the valves. I had a question about the butterfly flaps in the upper intake. Should they be closed completely when not activated? Mine have a gap, which hopefully shows up in the pictures.
Old Jul 13, 2020 | 08:05 PM
Wdp_3g's Avatar
Sorry I don't have the answer but does anyone have a part number for that little gasket thing I guess it would be on the bottom where it sits down in the manifold?
Old Jul 13, 2020 | 08:13 PM
https://www.oemacuraparts.com/v-2008...ntake-manifold
Old Jul 13, 2020 | 08:21 PM
Wdp_3g's Avatar
oh thanks never even saw that I already ordered the manifold gasket kit and was hoping it would come with but didn't
Old Jul 13, 2020 | 09:55 PM
But to OP, I BELIEVE it should be closed when the engine is off.. I took mine off to do a valve adjustment this weekend and i believe it was closed as well.
Old Jul 13, 2020 | 10:08 PM
Wdp_3g's Avatar
yep it's supposed to be closed jsut went and checked my extra type s manifold
Old Jul 14, 2020 | 08:53 AM
6for2's Avatar
Thanks all. I'll have to investigate why it's not closing..
Old Jul 14, 2020 | 10:28 AM
6for2's Avatar
If it turns out that the IMT solenoid is bad, is there any alternative to the 17150-RNA-A01 that's less expensive, or is the OEM part the way to go?
Old Jul 15, 2020 | 04:10 PM
Wdp_3g's Avatar
not sure myself but could go to a junkyard if you have one local mine always has tl's
Old Jul 15, 2020 | 06:36 PM
6for2's Avatar
It's much worse than I thought. Did a leakdown test today and the results were not good. Going to pull the heads...
Old Jul 15, 2020 | 11:17 PM
csmeance's Avatar
here are all the honda's that use the same valve:
https://www.hondapartsunlimited.com/...ve-17150rnaa01
The leakdown was done with each cylinder at TDC? any change with a wet cylinder?
Old Jul 16, 2020 | 07:55 AM
6for2's Avatar
Thanks. I have two Odysseys and I was thinking on substituting a valve from one of them to test.
Leakdown tests were done at TDC using the marks on the front cam. I did not try adding fluid. I also discovered that whoever installed the timing belt got the back cam one or two teeth off. That's certainly going to affect performance.
MrVtech
Dec 7, 2016 10:42 AM
Kcjason1
1G TSX Problems & Fixes
Aug 18, 2016 11:25 PM
AnthraciteTypeS
Jul 16, 2014 09:07 PM
bioyuki
Dec 31, 2013 08:28 AM
dsalazar1
Aug 9, 2010 08:17 PM
