Transmission slip?
Old Jun 8, 2019 | 02:23 PM
Pjarmon's Avatar
Transmission slip?
Back here again. My transmission has a hard transfer from 1st to 2nd, and 2nd to 3rd gear. It’s switches gears at at the correct rpm (2500) but it’s very ruff. Also I saw my transmission mounts were bad when I was changing out the motor mounts. Could this be the culprits or is the actual transmission going? Any answers help thanks
Old Jun 8, 2019 | 04:40 PM
Ron A's Avatar
Administrator
Welcome to the forums.
This post/thread has been moved from the Car Talk Forum to the model specific forum for better response.
Old Jun 8, 2019 | 06:05 PM
csmeance's Avatar
what color is the fluid? If it's not pinkish red you need to change it. Also highly recommend replacing pressure switches! If you have an 04-06 you have an internal filter that can be changed and will help shift quality a lot.
Old Jun 8, 2019 | 08:26 PM
Pjarmon's Avatar
The fluid is good just recently changed. I’ll look into replacing the pressure switches! Also by internal filter do you mean the cabin air filter?
Old Jun 8, 2019 | 09:01 PM
csmeance's Avatar
There is a orange colored transmission filter under a cover, under the engine air filter area under the hood. There are a few write ups on how to change it.
Old Jun 9, 2019 | 09:24 AM
Slpr04UA6's Avatar
-------Tim-------
https://acurazine.com/forums/third-g...t-pics-787078/
gotmilk221
Mar 15, 2005 09:35 AM
scoob5555
2G CL Transmission Recall Q & A
Jan 29, 2005 02:11 PM
rayman1031
Jul 19, 2004 12:43 AM
Y2K_TL
Feb 26, 2002 10:19 AM
