Transmission slip?
Back here again. My transmission has a hard transfer from 1st to 2nd, and 2nd to 3rd gear. It’s switches gears at at the correct rpm (2500) but it’s very ruff. Also I saw my transmission mounts were bad when I was changing out the motor mounts. Could this be the culprits or is the actual transmission going? Any answers help thanks
Welcome to the forums.
This post/thread has been moved from the Car Talk Forum to the model specific forum for better response. |
what color is the fluid? If it's not pinkish red you need to change it. Also highly recommend replacing pressure switches! If you have an 04-06 you have an internal filter that can be changed and will help shift quality a lot.
Originally Posted by csmeance
(Post 16437057)
There is a orange colored transmission filter under a cover, under the engine air filter area under the hood. There are a few write ups on how to change it.
