Trans locked in neutral after high speed mobbing
Old Oct 20, 2021 | 02:46 PM
FromTheFar's Avatar
3rd Gear
Hello i have a 2005 acura tl base with auto trans, 129k miles, no mods, only services done were battery oil and sparkplugs at 128k after i purchased car from auction.
Ok so, i was driving from a mountain range on the highway with a friend and we were really on the pedal going 80-100 through curvy sections of the highway for about 20 mins. Then we get on a few nice straightaways and i hit 150mph! Ahead of me Highway starts curving, we slow down to about 100 and we cruise at that speed for about 1 min before i hear a loud “click” and all of a sudden my car is in neutral and my pedal isn't doing anything! I pull over shut off the car let it cool down for 15 min start it up and shift it into reverse and nothing happens! Same with drive, and lower, and manual mode(1&2 do not work) also no CEL! I checked the trans fluid next morning and it is BLACK! (Already purchased dw1 atf for full flush but never got to it!) It is level and there are no leaks or holes in the transmission! So im guessing the transmission overheated and locked it self out! Im also guessing that my shift solenoids are completely clogged and the other sensors that the trans has are too! Car still wont shift into gear after getting it towed and it sitting all night! Im thinking about ordering a sins transmission solenoid kit with all sensors, i dont know if that will help! Let me know how you guys think i should procced!
Old Oct 20, 2021 | 02:51 PM
Old Oct 20, 2021 | 03:30 PM
Midnight Mystery's Avatar
Null and proud of it
Old Oct 20, 2021 | 04:45 PM
peter6's Avatar
Broken axle?
Old Oct 21, 2021 | 12:26 AM
sounds like a broken axle to me as well.. if you're lucky
Old Oct 21, 2021 | 10:02 AM
TheSauceBoss's Avatar
I have not heard of a trans "locking itself out" but then again I am not a certified Honda mechanic. If you did not get any codes, nor any other evidence of your trans overheating or failing, I would also venture to say that it's your axle.
My experience was similar when I broke one of mine, your gear selector will not work (your differential has no resistance and will not do anything). Mine was making quite a racket though, flopping around in the fork at the bottom of the shock/strut. The axle spins at idle but you will not be able to give any power to it. If both axles visually appear okay, remember to take a look at the intermediate shaft. You will have to get under the car to inspect that. Give it an inspection and let us know.
Also, I hate to sound like a buzzkill but if you're "mobbing" @150mph on cooked trans fluid and having parts of your car fail at the same time, you ought to be more careful doing that stuff unless you're confident in the state of the parts on your car.
Old Oct 28, 2021 | 12:22 PM
t-rd's Avatar
Good luck, and pray that ATF change will fix it. If you are going to fast and furious without protection measures on the trans such as a trans cooler, then you'll see the aftermath quickly.
Old Oct 28, 2021 | 04:06 PM
BreezyTL's Avatar
Didn't go 20!
Old Oct 28, 2021 | 06:00 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Proceed by getting a bus pass.
Old Oct 29, 2021 | 03:18 AM
comkb's Avatar
if it was an axle he would see his speedo go up? and his car would not stay still in park.
Old Oct 29, 2021 | 09:39 AM
OP doesn't make either of those claims....but it would be helpful if he provided an update to this thread here
Old Oct 29, 2021 | 11:41 AM
BreezyTL's Avatar
Probably got it working again and mobbed it to 150mph again with a different outcome. Hopefully nobody gets hurt while he drives like an asshat.
Old Nov 4, 2021 | 04:56 PM
Abe_Froman's Avatar
I had to Urban Dictionary "mobbing". It means "driving around with your friends and/or bitches, bumping music, having a good time, and hopefully picking up some more bitches".
I'm not even 30 and I feel old.
Old Nov 4, 2021 | 07:44 PM
Pair of TLs's Avatar
YOU do?? It is to laugh... I just guessed...
Old Nov 5, 2021 | 02:35 AM
If that's the case I do a lot of mobbing then, but it's a solo....
Old Nov 13, 2021 | 10:19 PM
comkb's Avatar
sorry i didnt know how to quote but it was in response to other people guessing it was an axle.
Old Nov 15, 2021 | 12:07 PM
Marsalis Simms's Avatar
UA7_Unknown
Believe it or not, TL's are not race cars.
Old Mar 9, 2022 | 05:25 PM
FromTheFar's Avatar
3rd Gear
Did a trans flush with filter, checked the solenoids (screens were clean, i cleaned them anyway) and swapped both axels! And......nothing. Car still doesn't go into gear and no check engine!
Old Mar 9, 2022 | 05:39 PM
Old Mar 9, 2022 | 07:14 PM
FromTheFar's Avatar
3rd Gear
Maybe solenoids are fried from high temp?
Old Mar 9, 2022 | 07:24 PM
Swap an 06-07 AV6 trans. and be done.
Old Mar 16, 2022 | 10:46 AM
JavierC24's Avatar
To think I almost did this to my TL when I got it, 120 mph on Miami Beach bridge. My vape juice was boiling in the cup holder after a couple miles at big speed. For the love of all that is holy change the gunk the previous owners called tranny fluid.
Old Mar 19, 2022 | 01:54 AM
Just put the vape juice in the transmission, gives it 20 extra horsepower
Last edited by Midnight Mystery; Mar 19, 2022 at 01:55 AM. Reason: Do y'all even fucking check this? If so, pm me, I'm curious if y'all really do!
00TL-P3.2
Mar 9, 2022 06:06 PM
SodaLuvr
Feb 7, 2008 11:14 AM
SodaLuvr
Feb 4, 2008 11:00 AM
konrad1978
Dec 13, 2006 07:06 AM
yanotkaj
2G CL Transmission Recall Q & A
Feb 14, 2002 12:59 PM
