TPMS problem...
TPMS problem...
I have an 08 TL. Traded my stock rims for type s rims over summer. forgot I had TPMS sensors in my wheels, dumb. so I ended up buying used ones off the BM on this site for like $60, great condition.
Got them installed today and they are not kicking in, MID still says error. Is there something that has to be done for them to work?
BANNED
no there is nothing that has to be done for them to work.
if they are installed properly, they will self-calibrate within a few miles of driving.
either your installer didn't mount them properly, or they're damaged, or they're the wrong sensors, or you haven't driven on them enough for them to calibrate.
after 40 miles of driving, still not working. prob something wrong right? or could need more time?
could it have anything to do with the fact that ive been driving around for about 5 months without any sensors in? idk
BANNED
take off the negative terminal of the battery and let it sit for like 5-10 mins. its a 10mm bolt.
^although i don't see how resetting your battery has anything to do with the TPMS.
sensors are the same for ALL 06-08 models. they do have OEM sensors, and aftermarket ones though. but it's just different part numbers (diff companies)...the product itself is the same.
BANNED
no...not quite.
what does it say on your MID? error?
BANNED
^well, either the sensors are damaged or they are not installed properly. take the car back to the shop and have them dismount the tires and make sure the sensors are seated properly. if they are, then your sensors are trash and you'll need to get new ones.
vendor AckTL05 can get you brand new ones for a little over $100 shipped.
You're really taking a chance by buying used TPMS Sensors (sensors is repeated). The TPMS sensor batteries should last 5 to 8 years and the batteries are built into the sensors so the customer would need to buy a new sensor(s) every so often. The 5 to 8 years is considerate of a good battery that was placed into the sensor. For everything that consumers buy, there are defective batches so therefore you may have bought a defective sensor.
okay, thanks for help. taking car back to have the guy make sure they are mounted right. if they still dont work then I guess they are bad and guy here on azine better give me my money back...
BANNED
^i'm going to go with no
plus the fact that you bought them used, you have no proof of when they were manufactured or where they even came from.
good luck and let us know what happens.
thanks for all the replies man. but how would they know they were purchased used? they are oem sensors. thanks
BANNED
^i mean, they won't know they were purchased used.
but YOU don't have any proof of purchase besides the fact that you bought them used haha. so either way, you're kinda stuck.
idk...like i said, i don't think they're covered under warranty. it's sort of a wear and tear item because they do indeed have a lifespan of 5-8 years or something like that.
well I would just say they randomly stopped working loll... wont mention that they arent the original
I emailed curry acura (just cause I had there email on hand from ordering side markers), and they actually said that tpms sensors are covered under warranty as long as they are not damaged. gonna call my dealer tomorrow... ill keep you updated.
Update: sensors randomly started working today. I think the warm weather may have had somethin to do with it. I actually have a $100 credit at Acura because I or my battery replaced not realizing it was still covered under warranty. So Acura gave me a credit which I was thinkin about using for the sensors. So now I have $108 to spend at Acura, any ideas?
any decent mods I can do for around $100?
And does anyone have any input about what may have made the sensors suddenly kick in after being in my tires four around a month and half? thanks
neuronbob
23
07-16-2019 10:48 AM
